Replacement Intake Hoses
Old 03-02-2014 | 04:01 PM
goodgenes79's Avatar
Default Replacement Intake Hoses
I am referring to the hoses that connect our intake plenums to the Y-pipe and then the one from Y to Intercooler. Has anyone replaced these? Did you go back with AMG hoses or just the autozone replacements?
I was replacing the plenum gaskets on mine and noticed a cut/tear in one of my hoses going to the y-pipe. It is on the inside and further inspection doesn't look to be clean through, but will be replacing asap. This may be the culprit of a leak I have been trying to track down. Anyway, if you haven't inspected these lately be sure to soon. cheers
Old 03-03-2014 | 12:31 PM
Default Re: Replacement Intake Hoses
If it does not go through how can it leak?
Old 03-04-2014 | 12:12 PM
There were several cuts inside the hoses and I have t-clamps holding them on, which add more pressure mushrooming the hoses. I will clarify that they APPEAR to be ok, but with their age and visual damage, might be leaking with enough pressure.
Edit: I picked up the usual Fuel filler, or reinforced coolant, hose in 2.5" to replace the OEM hoses. I am pretty sure they will hold up and are a tad more durable than the originals so should stand up to the added clamping pressure the t-clamps provide. we shall see.
waldig
09-02-2015 11:02 AM
Kazmeow1
08-03-2015 03:59 PM
07-29-2015 06:13 PM
crymar
07-17-2015 08:46 AM
Quick Reply: Replacement Intake Hoses
