Tranny fluid and washer fluid reservoir, repair cost estimates sought
Old 01-13-2014 | 09:00 PM
MRethman's Avatar
Default Tranny fluid and washer fluid reservoir, repair cost estimates sought
Re: 2005 SRT Roadster
15000 mi.
Honolulu
Yes, the window in my convertible top fell out too, Chrysler will not replace because it was "delivered" in MI, auctioned by Chrysler to a Dodge dealer in So. VA, from whom I bought via Ebay with 3 miles on the odo in 2007 with 33 mos. of new car warranty. Window fell out in late 2010, three mos. after warranty over. They didn't care that I had an extended Platinum warranty.. What laugh Chrysler is, fitting it's now owned by Fiat. Never will I buy from them...!. I've phoned them, my car doesn't qualify for replacement as if where it was delivered somehow explains why these rear windows are falling out nationwide.... NHTSA complaint in too, heard nothing back.
All that said, two questions:
1) I have a slow leak from the auto transmission; my guess is that the gasket is failing. Any idea what I should expect to pay the local Chrysler dealer to replace (and replenish the auto tranny juice)?
2) Also have what appears to be a failed windshield washer reservior (fluid leaks out all over the ground or garage floor). The reservior appears to in a wheel well, necessitating removal of wheel, removal of shrouding for access from below. Same question, any idea on what I should expect to pay for repair?
I have the skills to do these myself but lacking a lift and good knees, it's time to pay the piper.
Thanks in advance for your input!
Aloha, MR
Old 01-13-2014 | 09:10 PM
Default Re: Tranny fluid and washer fulid reservior, repair cost estimates sought
Does the washer fluid leak all the way to empty or close? or just when you fill it to the top? It will leak if you fill it to the top. Check your owners manual. If it does have a leak, you can access it through the wheel well.
Sounds like the electrical connector leak at the trans. Very cheap part to replace, just some labor involved. Some here have done it on the floor, I have done it on a hoist and much easier.
Do searches here and you will find a bunch of information to help you out.
James
Old 01-13-2014 | 10:02 PM
NOt a hard or complicated fix, (the transmission that is).
Print the tutorial here out, and take it to a mechanic you trust - don't bother with the dealer.
Old 01-13-2014 | 10:52 PM
dinasrt's Avatar
Truer words have never been spoken! You said you'd never buy from them again, so why let them rip you off in the service dept. where they really make their money. It's hard enough to find a Chrysler Dealer mechanic that really knows the Crossfire here on the mainland; I can only guess that Hawaii would be more of a nightmare! If you're 1/2 way mechanical, you can do the trans.plug replace yourself for around $15.(if that is what it is). Check out the HowTo's here on the Forum.
Old 01-15-2014 | 02:57 PM
Billy22Bob's Avatar
$15...??? maybe if you reuse the tranny fluid - best replace it while you do the job.
Old 01-15-2014 | 03:58 PM
dinasrt's Avatar
Less than $15! You jack up the passenger side real high and lose practically nothing! No need to change the fluid unless it's due or near due. I only lost 4 or 5 tablespoons IIRC, but if you didn't notice your leak for a long time or the leak was more severe, then definitely check the level and top up to spec. There are HowTo's here for all of this.
Old 01-15-2014 | 05:15 PM
Billy22Bob's Avatar
I dont know where you heard that one - but I reckon its one of those keepers....sooo....many people with thousands of 722.6 tranny's would have drained sumps and replaced filters etc. with this job and this little idea is a corker!!....
good stuff!
Old 01-16-2014 | 08:33 PM
dinasrt's Avatar
good stuff!
Heard what one? You obviously missed my point, and haven't paid attention that many of us here have done just exactly what I mentioned, and saved trannny fluid change and mess until it was actually due. Quite simple concept....... but leave it to you to over think it, and suggest how stupid(corker) it is.
Old 01-16-2014 | 10:29 PM
Abaton6's Avatar
I thought a corker was a good thing. Not sure now.
Old 01-17-2014 | 03:31 AM
dinasrt's Avatar
Now you have me wondering also. If he meant it as a good thing or compliment, then I apologize.
Old 01-18-2014 | 02:11 PM
Billy22Bob's Avatar
Default Re: Tranny fluid and washer fluid reservoir, repair cost estimates sought
yes corker here in Oz means - terrific! ...so yes - terrific idea.....
Old 01-18-2014 | 02:24 PM
I have found Yanks easily get the wrong end of the stick and get upset because they do not understand slang terms. They have a tendency to take something they do not understand as an insult.
Go easy on them, after all they don't speak English.
LOL
Old 01-18-2014 | 10:00 PM
LOL
LMAO...is that the problem.....you ole' bugger....
Old 01-18-2014 | 10:05 PM
15000 mi.
Honolulu
Aloha, MR
Definitely do what James suggested on the tranny leak. If that car came from an area where there were freezing temps, it may have cracked the reservoir allowing washer fluid to leak out. You might be able to remove it and repair it, or find one at a junk yard. The top, well, I would keep bugging every Chrysler dealer on the your island and the others until I had satisfaction along with calling Chrysler weekly. Sold up north or not, it should be covered. If you can't do the repairs, any good private mechanical shop can do them. I wouldn't take it to a dealer unless they want to warranty it. Good luck
Old 01-19-2014 | 02:38 AM
dinasrt's Avatar
LOL
You use to be a lot funnier Dave . I couldn't help but notice your use of the word "They" (four times) in your little pearl of wisdom. And because I was taught to respect my elders, I'll refrain from any further comments about the Yank bashing. LOL
Old 01-19-2014 | 09:33 AM
[QUOTE=dinasrt;776883]You use to be a lot funnier Dave .
And that was when?
Old 01-19-2014 | 04:20 PM
dinasrt's Avatar
LOL. Love ya Dave. You're my favorite curmudgeon.
Old 01-19-2014 | 08:59 PM
Mrmiata's Avatar
LOL
Guess Sparkie isn't going to jump in for an insult towards American heritage.. Kinda biased isn't he..
Old 01-19-2014 | 09:26 PM
SparkieSRT6's Avatar
SSB SRT6 405hp/401Tq
I'm biased because I didn't jump in to insult Americans?? WTF...just another one of your sarcastic posts looking for a reaction.
Old 01-19-2014 | 09:29 PM
Mrmiata's Avatar
Think you have that bas ackwards..
Was wondering where the lecture for 180 was.. not an issue since it was an insult to "American" heritage I guess..
Quick Reply: Tranny fluid and washer fluid reservoir, repair cost estimates sought
