Suddenly no brake lights-anybody else?
Old 08-07-2013 | 09:23 PM
carnuts's Avatar
Default Suddenly no brake lights-anybody else?
Hey all....Lost all brake lights over the week end. Everything else works fine and no idiot lights on. I have been doing some research and it seems the SRT-6 uses a special brake system that does not have a conventional brake light switch down at the pedal. Possible I may need a new brake booster?! Has anybody else had a problem like this? HELP!
Old 08-07-2013 | 09:39 PM
Default Re: Suddenly no brake lights-anybody else?
BRAKE LAMP SWITCH
DESCRIPTION
The plunger type brake lamp switch is mounted to a bracket attached to the brake pedal assembly under the instrument
panel. The brake lamp switch cannot be adjusted or repaired. If faulty, worn, or damaged, the entire unit must
be replaced.
OPERATION
The brake lamp switch has three internal switches with a single, six blade harness connection at one end. When the
brake pedal is in the released position, the plunger on the outside of the brake lamp switch is forced inward, which
opens the circuit. When the brake pedal is pressed the plunger is released, and the circuit is closed. This action
completes the brake lamp circuit, and allows the brake lamps and center high mounted brake lamp to illuminate.
The booster has nothing to do with it.
Old 08-07-2013 | 10:57 PM
carnuts's Avatar
Seems that description you sent apply's to a non-srt crossfire. My brake light switch has only 1 plug(with 3 wires) where as the non srt apparently uses 2 plugs (with 3 wires on each). I have already changed the brake light switch and checked bulbs and fuses related to the stop lights. Also replaced a sensor in the booster which made no difference either. Do appreciate the quick reply. Any other ideas?
Old 08-07-2013 | 11:29 PM
robby363's Avatar
Did you check fuse #2 in the illumination control module fuse block located on the driver side dash? It could be the illumination control module it's self and would need to be replaced if it is.
Old 08-08-2013 | 07:31 AM
BRAKE LAMP SWITCH
DESCRIPTION
be replaced.
OPERATION
Dave, I searched for "Brake Lamp Switch" in the srt6 service manual, what I found is :
OPERATION
The Brake Lamp Switch is integrated with the BAS Solenoid Valve. As the brake pedal is applied, the brake switch
is activated and a signal is sent to the CAB module. The CAB then grounds the coil side of the brake lamp relay.
This action completes the brake lamp circuit, and allows the brake lamps and Center High Mounted Stop Lamp to
illuminate. When the brake pedal is released, the plunger returns to its rested position, and the brake lamp relay is
de-energized. As the relay is de-energized, the brake lamps are again returned to their off state.
Here is some more info. Kinda confusing, I'd say .....
Old 08-08-2013 | 04:48 PM
meh03's Avatar
Same exact thing happened to me a couple years ago when I went to get it inspected. I ended up taking it to a shop who had to trace the electric. They said it is a mess how many of the systems in our car are tied together. After a few days and a few hundred bucks (which was cheap for the time they put in) they figured it out. It was a break relay, as I recall somewhere around the back passenger portion of the engine compartment. Sorry I can't be more specific, but if you can get an electrical diagram of the car you can probably track it down easy enough and replace it cheap
Old 08-08-2013 | 05:03 PM
Yes. The brake light relay is the one on the left ( there are 2 ) as viewed from the front of the car.
They are at the rear of the under hood accessory box which is by the fender behind the antilock brake stuff.
( The one on the right is the alarm relay )
Old 08-08-2013 | 09:48 PM
carnuts's Avatar
Update...its fixed. As some mention the brake lamp relay (yellow one) did the trick! Just took a few days to get one from NAPA. Thanks for all your input. This forum is the bomb.
Old 08-09-2013 | 06:36 AM
Thanks for getting back, glad to help.
Valk
01-16-2023 10:49 AM
chturner
19
10-14-2019 04:42 PM
RamblinShamblin
08-12-2017 10:55 PM
8ighth Wonder
12-15-2015 01:42 PM
ritous1
09-26-2015 01:27 PM
Quick Reply: Suddenly no brake lights-anybody else?
