pulley for srt 6 which is the best?
Old 11-04-2013 | 07:08 AM
Default Re: pulley for srt 6 which is the best?
I may be mixing my 62mm into this as I have changed so many pulleys in the past. I use a Gates belt on the 65mm with a pulley wrap kit. Part # K081153. That is a 1 3/32" X 116 1/4" OC. That doesn't sound like the stock belt to me, but now I am not sure. I can't get to the 62mm belt to check it right now. I know it is different. Either way, Rob at Needswings can supply with the right belt. Shorter may not be correct now that Billy22bob mentions it.
Stock belt 1 3/32 X 115 1/8" OC without the pulley kit. That is Gates Part # K081145. This may be the confusion for me. I run pulley wraps on both cars. So I have changed too many times to be sure. Here's at least a belt for the wrap kit, and for without anyway....
UPDATE:
Billy22bob is correct. Looks like from my notes, the K081145 is a stock belt. So we are running the 65mm without a belt wrap kit with a stock belt. My fault, my confusion. Too many belts, too many cars, too many belt wraps....thanks Billy22bob for catching my error.
Old 11-04-2013 | 08:31 AM
Kjohnso5's Avatar
If I can run a 65mm pulley with the stock belt, at least for now, for street driving that would be great.
Much appreciated oledoc2u and Billy22bob.
Old 11-04-2013 | 02:16 PM
C_DirtyTwo's Avatar
if you're looking for a deal on a great pulley I have the 185mm and pulley saver kit for sale PM me
Old 11-04-2013 | 04:56 PM
NeedsWings's Avatar
we only recommend/sell one pulley kit for a reason that is what we run on both the srt6 and c32
Old 11-17-2013 | 04:58 AM
2much2handle's Avatar
Default
Rob what kind of gains am I looking at with your complete pulley kit. I already have you single cai. and removed all cats and resonator. currently dynoed @ 320 untuned. just looking for a ball park to have an idea. thanks in advanced. Alex
Old 11-18-2013 | 09:46 AM
NeedsWings's Avatar
"ASP claims a very modest 20whp with their kit but the seat of the pants difference is incredible. I wouldn’t be surprised to see 30-40whp on the dyno."
Old 07-06-2015 | 03:51 PM
4drturbo's Avatar
Originally Posted by Billy22Bob
blueeyes - you might want to rephrase this sentence....
".....then the best possible combination pulley / filter already I mount the module eurocharged tcu gearshift pedal gear solenoid valve to the original exhaust and tuning the engine control unit "
With stock intakes etc. and 155 crank...the 65mm will give you +30rwhp (from stock 290) with no AFR concerns. She will get high IAT's quickly without cooling mods. But if its just for a short squirt off the lights against a rice burner - fine. The 62mm will give you +40 (from stock), but IAT's are up to another level and touch and go on the fuel (with stock inlet) so AFR gauge essential.
DCAI will give you another 10rwph, but with the 62mm and DCAI it appears you will go lean and fuel mods are the order of the day.
EZ street - 155/65mm and DCAI will net you almost 330rwhp for short spurts for <$1,000.
Enjoy this post.
With that said, and it is now 2015. What are you all running for a smaller pulley?
I am looking for a bit more power and was told the most reliable pulley for our car is the EuroCharge 64.7mm. Are there members with quite a bit of mileage on this pulley? They are aluminum though, will that be a long term issue? I just need some guidance.
They sell it for $475. Adding a ECU tune puts it up to $875 total. Is the tune needed after pulley install?
Not looking to do fuel mods or anything crazy. I have the DCAI installed.
Thanks for all and any insight!
Old 07-06-2015 | 07:49 PM
philosophico's Avatar
Originally Posted by 4drturbo
Enjoy this post.
Stock pulley is made out of steel for a reason, so with that in mind I order one from the guy in poland on ebay, it is a 65mm made of steel. It actually arrived today, ill prolly put it on this weekend when the pulley saver kit from Rob arrives. Im only changing my pulley now because the bearing has started to go in my OEM pulley, I bought a new bearing and was just going to swap it out but decided eh, why not get a smaller pulley for a lil more boost. I'll see how reliable this car is with a 65mm pulley on it at 151k miles.
Old 07-08-2015 | 04:55 AM
austinbarrylee's Avatar
Who's running 62 stacked
Old 07-08-2015 | 01:04 PM
I'd like to know as well. I'm running a 62 karma pulley not stacked. As far as I've been told you can't stack the 62 because the charger can't handle it. If someone has otherwise please share.
Old 07-08-2015 | 01:35 PM
Originally Posted by 2much2handle
I'd like to know as well. I'm running a 62 karma pulley not stacked. As far as I've been told you can't stack the 62 because the charger can't handle it. If someone know otherwise please share.
Previous comments says 62 and 178mm.
Old 07-08-2015 | 02:11 PM
Thanks for the info.... I had read that. I should have specified looking for info on someone that has 62mm pulley stacked. And can share what their experience has been gains, reliability, ect....
Old 07-08-2015 | 02:15 PM
I'm trying to find out info too about it.
Old 07-08-2015 | 02:26 PM
I would say get ahold of grip grip, boostmonkey,
Old 07-08-2015 | 02:30 PM
Just sent a message to Rudy / rcompart. A soon I hear anything I'll post his advice.
Old 07-08-2015 | 02:31 PM
I would say 62 stack would be insane
Old 07-08-2015 | 02:34 PM
probably would be insane but hopefully do able lol.
  #38 (permalink)
Old 07-14-2015 | 01:00 AM
Zoodust's Avatar
Not to be the downer here but... pretty sure 65/178 is the combo you need to go if you want to stack... along with lots of fuel and cooling mods to go along with it
  #39 (permalink)
Old 07-14-2015 | 07:57 AM
velociabstract's Avatar
Super boost with our supercharger, 22psi and up, IMO brings as many negatives …. or more, than positives. Based on running stacked a few days and taking the car to the track. The car was a beast down low. High boost at low revs. Up top the power trailed off, a lot. It wasn't real lean so my guess is the extra boost created was negated by the extra power to turn the supercharger. To run stacked safely you'll have to do a whole bunch of supporting changes to the fuel system which take time, patience and money. Do your research, dream big, don't ignore others experience when you decide what to do.
Les
  #40 (permalink)
Old 07-14-2015 | 01:33 PM
Zoodust's Avatar
Les
+1. I've even gone as far and emailed Eurocharged on advice for runing stacked pullys... basically they say If you don't have the reworked cylinders and valves or perfect fuel and cooling mods beforehand then it's not even worth trying ! Also take into consideration for your elevation, as that can effect boost slightly. When your running 22+ it's important to know how fast that SC is spinning
Quick Reply: pulley for srt 6 which is the best?
