Just Got My Crossfire Srt6 Roadster
Old 04-21-2013 | 08:53 PM
lang's Avatar
Default Just Got My Crossfire Srt6 Roadster
] just bought my car and when I turn on the a/c the air comes out the drivers side and heat out the passenger side. Has anyone had that problem and have do you fix it ???
Old 04-21-2013 | 09:10 PM
RL67037's Avatar
Default Re: Just Got My Crossfire Srt6 Roadster
These cars have dual zone controls. Turn the dials on either side of the A/C controls to "blue" - that will get you cold air. Turn them to "red" and you will get hot air.
RL
Old 04-21-2013 | 09:35 PM
lang's Avatar
Both on cold
Old 04-22-2013 | 02:31 PM
Bigkid's Avatar
Welcome to the forum Lang. Sorry I can't help with the hot air cold air issue. Try turning everything (hvac) off and on including the a/c and see if it will reset.
tell us where you are located and more about your SRT. I am sure you are going to love the car.
Old 04-22-2013 | 02:57 PM
RL67037's Avatar
Here is a thread that may have an answer:
https://www.crossfireforum.org/forum...ad.php?t=56274
The poster had the same issue that you are having. You might PM him and see what fixed it.
RL
Old 04-22-2013 | 03:07 PM
lang's Avatar
It's a 2005 Crossfire Roadster with a little over 20000 miles. I live in Maryland and got the car from Pennsylvania. It has a few things added on to it. It is black.
Old 04-22-2013 | 03:30 PM
lang's Avatar
Default
Originally Posted by rl67037
here is a thread that may have an answer:
the poster had the same issue that you are having. You might pm him and see what fixed it.
Rl
thanks rl67037
Well there is your problem. You picked a bad color.
Your problem sounds like an actuator problem closing the heat off of the drivers side. If the car (20K miles in 7 years) was in storage it may just be stuck. The baffle doors are vacumm operated so perhaps it is just a hose loose.
Or it is just stuck.
Also try downshifting to rev the engine with your foot off the gas. That will supply more vacummm to the system. Might shake it loose.
Remember, it is a Benz. Best engineered cars in the world, assembled with the cheapest parts. Cheap unless you need to buy one.
Old 04-22-2013 | 04:02 PM
FUBU's Avatar
Congrats to the car! Hope to see you on SRT-6.com (vin# gallery, vin# survey, engine bay gallery) enjoy the car!!
Old 04-22-2013 | 05:01 PM
lang's Avatar
I just bought my car and when I turn on the a/c the air comes out the drivers side and heat out the passenger side. Has anyone had that problem and have do you fix it ???
Old 04-22-2013 | 05:06 PM
Duct tape
Old 04-22-2013 | 05:42 PM
Mrmiata's Avatar
Sounds like it's in "date mode"... cool you down and heat her up..
Old 04-22-2013 | 05:52 PM
The problem probably lies in the solenoids under the hood that switch off the hot water to the heater core. There are two cores and two solenoids.
These adjust the amount of hot water flowing when they are in heat mode but shut off when in full AC mode. But if you have one of the ***** that adjust the heat set to hot then hot air and cold air will mix when in AC mode. The **** has to be in the "Blue" zone to see more cooling.
That's roughly the way it works.
Old 04-22-2013 | 10:37 PM
04Fire's Avatar
Sounds exactly like what onehundered80 mentioned... rather common to MB's
SuperD500
06-23-2015 02:48 AM
SuperD500
06-19-2015 02:40 PM
skip2mylue23
06-09-2015 01:00 PM
MJPowers
06-08-2015 02:34 AM
bourbonton
05-29-2015 02:51 PM
Quick Reply: Just Got My Crossfire Srt6 Roadster
