SRT-6 is not liking to get on it
Old 02-24-2013 | 08:36 PM
srtmodder's Avatar
Default SRT-6 is not liking to get on it
Okay so normally driving around town with the car being fresh and not been running for an hour or so... the car will get up and go just fine and move very quickly but..... I have noticed when I have been on trips just 45 minutes some times or longer (upwards of 2 hours) I will put the throttle down to go around someone and the RPM's go up and the car just barely reacts and very slowly starts accelerating almost at an unsafe speed when trying to get out of the way. Although then it will move just fine later and have no problems its as if its here and then gone.
I have no great knowledge of what could cause this being new to this car. I have tried putting it in the slap shift mode thinking it was just not dropping into gear but it still didn't move then. Any help I? I am no mechanic and I don't know how to go about correcting this.
Old 02-24-2013 | 08:48 PM
grip grip's Avatar
Default Re: SRT-6 is not liking to get on it
Can't imagine what it could be. I think you definitely need a new supercharger.
JK, sounds like the intercooler pump.
Sounds like an IC intercooler pump issue. Plenty of info here about it. James
Old 02-24-2013 | 08:49 PM
Sounds like your IC pump or supercharger are failing
I'm sure some of the SRT guys here will further explain this
James.....beat me to it with the same idea
Old 02-24-2013 | 08:50 PM
stryfox's Avatar
Another vote for the ic pump. Do a search and check that first.
Old 02-24-2013 | 08:53 PM
JesseJamessrt6's Avatar
yes, IC (intercooler) pump. It is located at the front bottom corner of the passanger side behind the fog light. The supercharger clutch cuts off if the coolant gets too hot in the IC. Sounds like this is what you are experiencing. These pumps go out every few years. Easy and cheap fix. Upgrade to a johnson CP30
Old 02-24-2013 | 08:57 PM
srtmodder's Avatar
Well I am glad to hear it is a possible cheap fix and not an entire supercharger! ha Thanks I'll have to go check it out and confirm it but sounds like a reasonable thing. Dang Texas heat is never helpful!
Old 02-24-2013 | 09:15 PM
Dementors's Avatar
Sounds like the IC pump as I recently changed mine and had the same symptoms. It may be "easy" but not fun because you are not modding it out - boring maintenance! Get hose clamps....do not plug the hoses with something as bad things can happen...just saying.
Old 02-24-2013 | 09:26 PM
srtmodder's Avatar
Well I was just looking at the Johnson pump and was wandering how tough it is to replace? Pretty simple?
And heck I havent had the car in the summer yet to know how it will be in the extreme heat of Texas so I am looking to upgrades possibly.. the cooling package that NW has possibly? If I am going to make sure it stays cool then sounds like an option to go with...
Old 02-25-2013 | 04:20 AM
Buggin's Avatar
Do some research and choose the pump that you feel most comfortable with. I have my own thoughts with the hi-flow Johnson pump, but I'm not an engineer, so I won't elaborate. Personally, I'm using a Bosch from the Ford Lightning and its been working we for 60k+ miles. Also, don't forget to check the fuse.
Old 02-25-2013 | 07:53 AM
Performance auto parts & aftermarket auto accessories for your car, specializing SRT4, Crossfire SRT6, SLK32, C32 AMG, VR-4. He has the stock Bosch pump in stock. The 1st gens had problems.
Old 02-25-2013 | 04:08 PM
srtmodder's Avatar
So the replacement ones will last longer now? Not 30,000 and done?
Old 02-26-2013 | 09:04 AM
witchal's Avatar
There's an upgraded version of the stock pump available, direct plug & play. I got mine for $122.00 shipped.
Mercedes Auxiliary Water Pump - Bosch (OEM) 0392022010 | FCP Euro
I had the same symptoms and replaced mine this past weekend. Installation was pretty easy and took less than an hour from start to clean-up. It seems to have solved the issue.
Old 02-26-2013 | 02:25 PM
zombiehunter's Avatar
There's a different pump people use, the MB one Witchal linked is new to me. Lots of people, myself included tomorrow, use the Johnson IC pump from I believe the Ford Lightings with good results. I would bet my cat on it being your pump. Save yourself a few grand and just order the part today and install it yourself. Should solve the problem.
Old 02-27-2013 | 04:36 PM
srtmodder's Avatar
Well I gave in and ordered the Johnson CM30 and went a little further and bought the cooling package from Needwings as well.. So that turns out to be a super cooler, the pump, the ic isolation kit, and the chill charger fluid. Maybe I went too far but I mean it was just so dang tempting. ha
Old 02-27-2013 | 04:47 PM
stryfox's Avatar
Nice....
Keep us posted on your upgrades.
Old 02-27-2013 | 05:00 PM
have you heard of Needswings.com, not only is he a member of this forum, he has an SRT 6, he also sells parts like. The IC Pump,, intake , exhaust system ,, pulleys , and much much more for the SRT 6,,
stand behind his products and you can PM him any time on this site,, just do the search ,Needswings,
at least by using Needswings you know who you're dealing with, not just an auto-parts store. . jim
Old 02-27-2013 | 05:17 PM
The Beep's Avatar
If everythings working properly, it won't have any problem with the Texas heat.
Old 02-27-2013 | 06:47 PM
With all the problems people have with the OEM IC pump, I'm thinking that I will change mine out before it gives a problem. I am assuming that it still has the original pump in it. Even if it was changed I would think that it is still the old design.
I have a used Johnson as a spare but I'll ignore it I and replace with a new Bosch from NW. Does that seem the smartest thing to do? I am running the IC separation kit.
Old 02-27-2013 | 06:50 PM
bluecoupe's Avatar
I'm with you Dave, if/when my OEM pump fails I'll replace with the Bosch unit I have sitting on my shelf.
Quick Reply: SRT-6 is not liking to get on it
