Eurocharged Euro-Flash! Data Logging, OBDII Code Functions, and ECU Flashing!
Re: Eurocharged Euro-Flash! Data Logging, OBDII Code Functions, and ECU Flashing!
Here's the link to the instructions from the video in pdf form for those who may want to print them out...!!
http://www.eurocharged.com/Euro-Flash-V2.pdf
Just waiting IMPATIENTLY for the prog to be posted online. I'm already paid in for 2 tunes and I gots the cable!!
Jump over to the website and make your purchase... "should" show you at $300 purchase price..
All went well on the software! File sent in.. now the waiting game again.. LOL.
Hopefully with all they have going on I can be tweaked and tuned sometime Sunday..
Edit: Wellll... I guess operators are on standby.. call in now.. LOL
Flash file is back already!
Just have things to be a part of shortly so tune file will have to be applied in a few hours.
I've got a sweet spot getting on the turnpike that torque pro shows 165 HP. Be a perfect "repeatable" spot for a new reading..
PS Jake: Data Logging.. think blue tooth compatable... LOL
I got mine loaded this morning, the car is real joy to drive now. Two things to bear in mind that happened to me.
1. My ECU would not load the "Fast" process so I had to say No to doing it the second time I flashed. And I was successful that time.
2. As soon as it started loading the file to the ECU; my cooling fan came on full blast and I ended up disconnecting the fan on the drivers side. There is a connection right next to the radiator hose that has to cheesy plastic clips holding it on. My battery would have drained if I didn't disconnect the fan, it didn't harm anything and the car is sweet now. The next time I load a file I will disconnect the power connector to the fan. I had a battery charger on it and it was struggling to keep up.
It's nice to know my fan works real good!
I put the top down for the first time and I really like my wife's car now. LOL
Yes it does. I would like to know what the on and off temps are now for the electric fan, but won't know until we get some warm weather.
I think with the minor upgrades I made that I got the most out of the Euro tune. I won't be doing any other engine upgrades so I'm satisfied for now.
Most likely still good.. head over to the website and run through the checkout.. should see it as $300 for the NA and $350 for the 6.
Everything but the order number (which is on your receipt from Eurocharge) should fill in automatically when you have the "green" light in the lower left hand of the program.
This is when you hit the "connect" button on the page..
Does it give you an option to download new software? That was the issue with mine when I got it.
right click program icon and select run as administrator then okay for new software download if this is the case...
