Can you help with this noise/leak? Video inside
Old 02-08-2013 | 08:08 PM
zombiehunter's Avatar
Default Re: Can you help with this noise/leak? Video inside
ASP 178mm kit & PSK178
This is all I can find over on NS
Old 02-08-2013 | 08:25 PM
velociabstract's Avatar
It sounds like your supercharger pulley is failing. As a test see if the rattling changes when you turn the air conditioner on and off. The compressor changes the tension and will modify the rattle if the forum is correct and it's the pulley. Get an aftermarket 65 mm pulley and be done. It's the best way to go if it's indeed the pulley, which I'm convinced it is.
Les
Old 02-08-2013 | 08:37 PM
That won't help your situation if it is the supercharger pulley. That is a CRANK pulley. I do have a 65mm I would let go... let me know if interested...but, make sure it is the pulley...
Old 02-08-2013 | 08:43 PM
Les
Will check tomorrow, with video of course. Is the pulley something I can do myself?
Old 02-08-2013 | 08:54 PM
Pretty easy to do it yourself after finding a replacement pulley. Here's a video of my "bad" pulley.
Old 02-08-2013 | 09:49 PM
Thanks for the video. Mine isn't making the click in that direction. I'll check again tomorrow with the AC.
Old 02-09-2013 | 08:31 AM
beasticles's Avatar
Subscribed. Thank you to all who are posting helpful responses. We all know how shitty it can be when you're trying to diagnose an issue that you're not familiar with. Without all the helpful responses the OP might have spent a ton of money at a Chrysler dealer.
Don't know where you are located OP but try to find a independent Mercedes mechanic to diagnose it for you if after tracking it down as directed on this forum you still can't figure it out. Most likely if you're talking with any mechanic who has experience with the 3.2L engine (and preferably the AMG variant), he will recognize the symptoms quickly.
If you're in the Northern VA area by chance, I can recommend two good ones:
Silver Star Motors, Vienna, VA
Silver Star Motors : 703.281.5606
Autoscandia, Reston, VA
AutoScandia | Northern Virginia European Automotive Specialists Herndon VA | Virginia State Emissions Inspection and Repair Station, Foreign Imported Car Repair Washington DC | Reston, Fairfax County, Loudoun County, Saab Auto Repair, Volvo Auto Repa
Old 02-09-2013 | 01:09 PM
Checked the A/C thing, nothing happened...I didn't see any change anywhere though. I'll try again when I have someone to push the button while I'm staring at the belt. Thanks for the links, unfortunately those shops are kind of far away. Hopefully, I'll find something in the Annapolis/Balitmore MD area.
Old 02-10-2013 | 03:08 PM
RL67037's Avatar
When checking with the A/C on, don't forget to have your fan speed switch past the picture of the fan on the dial. I am pretty sure that the A/C compressor won't kick on unless the speed is past the picture of the fan.
RL
Old 02-10-2013 | 03:45 PM
grip grip's Avatar
I really don't think more experimentation is necessary unless you're trying to find additional problems. You supercharger pulley shouldn't clank against the magnet when pushed by hand. The springs should hold it away from the magnet until the magnet is engaged. You need a pulley. I'd refrain from driving the car until a different pulley is installed.
Old 02-10-2013 | 04:15 PM
https://www.youtube.com/watch?v=CT-L...e_gdata_player
Posting from phone. The part behind the clicking part I assume is the pulley and it did not make any noise when turned.
I think you can see that the rivet attaching the spring to the pulley is loose as the spring moves away from the pulley as it is pushed rather than stay firmly attached by the rivet. The movement can be seen at the right hand end of the spring.
So it is not the spring that has failed but the rivet or rivets.
Old 02-11-2013 | 10:58 AM
Ugh...thanks guys. And I've gotten a couple PMs regarding 65mm pulleys for sale, I appreciate those. But the difference between used and new isn't enough to get me to go used. Thanks a lot though. Expect more questions as it comes time to install. I'm going to search for some threads on it, anyone have the end all be all of pulley install threads?
Old 02-11-2013 | 11:21 AM
65mm pulley with tune, $875
Single CAI from Needswings, $450
I've got an email out to EC about install instructions and how their tune is done, I thought I read something about it being done remote via laptop or something. It looks like I'm going to gain ~50-75hp at the wheels and do it for several hundred less than the dealership wanted just for the pulley. Right track?
Old 02-11-2013 | 11:53 AM
NeedsWings's Avatar
Supercharger Bearing
i have 1 left in stock right now
you still need to find where the fluid leaked from, let me know what line ruptured/cut and we can get you a quote on that also. thanks, rob
Old 02-11-2013 | 04:36 PM
Thanks the pulley kit comes with the bearing. I'm really glad to see you selling those without the crap the dealer puts you through "oh, we'll need to replace the whole SC". Right up there with the guy telling the owner of a car it'll be $250 to replace his fuel filter.
TerryR
12-13-2019 03:27 PM
ATX SRT-6
10-12-2015 03:16 AM
MiamiTVR
Other Cars
09-29-2015 05:27 PM
ala_xfire
09-28-2015 05:51 PM
BEATv1
09-10-2015 12:58 PM
Quick Reply: Can you help with this noise/leak? Video inside
