going back to the bosch pump
Old 02-03-2013 | 02:31 AM
martyfa's Avatar
Default going back to the bosch pump
Bought my SRT with 26,000 miles on it and have 52,000 on it now and have already gone through two johnson intercooler pumps. Decided to go back to the Bosch pump but had cut off the power plug to accommodate the Johnson pump and am looking for anyone who switched to the Johnson pump but might have their original power plug laying around. Anyone??
Thank you for your help!
Old 02-03-2013 | 08:04 AM
waldig's Avatar
Talking Re: going back to the bosch pump
what was the nature of the failures if I may ask? Electrical or mechanical??? This seems very excessive. Do you do a lot of commuting in traffic or highway driving? I d guess you have stop and go driving mainly with that record. Thanks Woody
Old 02-03-2013 | 09:07 AM
ImportLabSRT's Avatar
Default Re: going back to the bosch pump
Sounds like the pumps are getting over worked. Have you checked for any restrictions in the H/E circuit? I will check my box-o-stock parts and let you know if I have the connector somewhere.
Old 02-03-2013 | 09:29 AM
Bigkid's Avatar
Check with Rob at Needswings. He may be able to fix you up.
Old 02-03-2013 | 10:16 AM
Yep. Pumps burn up if the flow is impeded. So switching may not help. Too many on here running Johnson's. I think we would have heard more complaints. I use Bosch myself. Cooling is still stock on my cars. So no need for more flow. Good luck.
Old 02-03-2013 | 12:30 PM
martyfa's Avatar
Driving is all local. A mixture of highway and stop and go. As far as the failure being electrical, mechanical or impeded flow I don't know how to check for that. (H/E circuit?) there's no crimps in the hoses in or out of the pump.
No warning indication lights on the dash.
Could I be doing the install wrong?
I can replace parts but am lacking in the diagnostics area.
Woody would you like me to mail you the pump once I swap it out?
Thank you
Old 02-05-2013 | 03:40 PM
beasticles's Avatar
I was in the same spot as you man. Do your wallet a favor and simply buy some of these at your local auto parts store and connect them to the cut wires that need to plug into the Bosch plugs and you are off to the races - one plug for each wire and each male plug.
https://www.google.com/search?q=wire...01%3B220%3B181
Old 02-05-2013 | 03:55 PM
grip grip's Avatar
I did the above, and them filled the plug with silicone to better secure the wires. Was still running strong after I hit a telephone pole.
Old 03-09-2013 | 07:34 PM
martyfa's Avatar
mrobinso and grip grip. Followed both of your suggestions and am up and running. Hopefully not into any telephone poles though!!:0) Sending the Johnson to Woody for further inspection.
Thank you
Old 03-11-2013 | 08:17 PM
klong's Avatar
While I knew that Woody is an extremely talented and knowledgeable individual, I never knew he did Johnson inspections,,,,
KevinL
Thank you
BrenLW
08-05-2015 04:53 AM
Romio
07-24-2015 07:03 AM
xfireon20z
07-20-2015 04:35 PM
Mark McKay
07-17-2015 01:18 PM
Tp'sfury
07-17-2015 01:15 PM
Quick Reply: going back to the bosch pump
