Intake manifold Toruqe specs
Old 01-01-2013 | 10:50 AM
cjw's Avatar
cjw
Default Intake manifold Toruqe specs
I got my new set of modded manifolds done and in being powder coated now, does anyone know the torque specs for putting the bolts back on? I checked needswings and the forum and could not find them.
Thanks
Old 01-01-2013 | 11:33 AM
rfourt's Avatar
Default Re: Intake manifold Toruqe specs
20 N-m or 15 ft lbs or 177 in lbs
Section 9 page 730 of Crossfire Service Manual
Old 01-01-2013 | 11:58 AM
JesseJamessrt6's Avatar
I would go with Steve's (32Krazy!) "i go inside (closest to the s/c) 2 bolts outside 2 bolts then front and rear to 5 ft/lbs repeat to 10 ft/lbs then repeat again to 10 ft/lbs. i use a in/lb torque wrench as the torque is low to begin with and a 3/8 drive shoots past quickly".
This is what I used and had no problems.
Old 01-01-2013 | 12:28 PM
cjw's Avatar
cjw
Copy that guys. Thanks for the help
Old 01-03-2013 | 03:42 AM
Billy22Bob's Avatar
MB Work Instruction Set (WIS) calls for 10Nm = 7.4ftlbs.
You gotta be careful with these aluminium/magnesium setups.
But I agree with Steve's inside out "creep up" technique.
PM me if you need a WIS procedure printout.
Old 01-14-2013 | 07:10 PM
Daddy's Avatar
Man you got good advice. When I asked this question I was told to go look it up on my own. Least I k.ow where all the specs are but at the time I was in the middle of the job.
Old 01-15-2013 | 02:08 AM
NeedsWings's Avatar
the instructions are on the gasket page on our website
Intake Manifold Gaskets
12-02-2015 12:49 AM
09-28-2015 07:40 PM
09-26-2015 10:21 PM
Dgiomatch1
09-20-2015 01:05 AM
Idrenak
09-19-2015 08:17 PM
Quick Reply: Intake manifold Toruqe specs
