New Intercooler Core anyone? OH YEAH, IT JUST GOT REAL!!!
Re: New Intercooler Core anyone? OH YEAH, IT JUST GOT REAL!!!
UPDATE:
These upgraded intercoolers are finished and can be purchased via the PayPal links below.
Accelerated Intercooler Upgrade for SRT6/32AMG - $1050 plus shipping
Accelerated Intercooler Upgrade for SRT6/32AMG w/ Installation Kit - $1240 plus shipping
I've seen enough threads about the old and busted OEM Intercooler. Know what I think... Fugetaboutit! So since we're not talking about that thing anymore, how about we discuss new IC cores and what they can offer. This isn't a hacked up air-to-air core but a custom sized air-to-water core made especially for this particular application. Inlet, outlet, endtanks and everything else will be scratch-built with only three things in mind, performance, fit and reproducibility. No preorders or anything at this time, just building it for my own car as my second OEM core just started wetting the bed after only being in the car 35k. If it works out, perhaps these will be available in the future.
For your viewing pleasure.
UPDATE:
the aftermarket IC's have not been produced in years, i have a few NEW OLD STOCK OEM IC's here left on the shelf (they have a 2006 build date), 1 used good one and a stack of dead leaking ones. not sure of the path we will need to take once they are all gone, the road is running out quickly.
Bob
Then send to Rob? So now you're saying that Rob fixes them? What am I missing here Jim?
Completely agree. Get a spare. They are easier to find and usually a bit cheaper when you DONT NEED ONE RFN
The RFN factor has an increase in cost associated because when you need one, there are non posted on eBay.
if you have some space, it’s a good idea to start collecting a second or third of the really hard to find items. Spares are always a lot more cost effective when you dont need them. If the item is rare, it may increase in value when you no longer need them down the road.
we do not repair them, all that i have seen tried have not held and ended up replacing the intercooler. that is for the ones that were lucky enough to crack in a pace that was reachable after cutting it open, if the crack is anywhere other than a "perfect" spot to crack there cannot even be an attempt.
Thanks for everyone's response. I appreciate the info. and good advice. Sure wish that Rudy and/or Accelerated would make another batch, and have them available for those in need in the future. My fault for not getting one of his as a spare when they were available. Always the money issue unfortunately.
I know radiator shops have built custom sized heater cores for me in the past and I would think should the need arise an Intercooler could be built. Hopefully there are still some shops around with the kowledge to do that type of work; Back in the days it was common to make your own.
The advice of getting that super charger cooling system separated from the engine is very important and then be very particular as to what you use as coolant. I'm using DEI because it has no phosphate; Similar to the Mercedes recommended engine coolant GO5 but made specifically for intercoolers.
Wow, if you really need one, you really don’t need to look to hard.
i found one in 35 seconds for $450 on EBay. Noted that 20 people are currently watching it.
It can be yours, you just have to press the buy now button. $450 is really cheap for an item that is critical
if you have a SC engine and you’ll receive it in a few weeks. No messing around, it’s a bolt in.
https://www.ebay.com/itm/25513857646...Bk9SR4bKuaTWYQ
