Dashdaq user input ground wiring, need urgent help
Old 07-23-2012 | 02:59 AM
Silverarrow's Avatar
Default Dashdaq user input ground wiring, need urgent help
Hi!
I have connected everything for the DashDaq and Zeitronix ZT-2 but I don't know how to connect the User Input wiring. I know that green wire is a +5v sensor input but where should the ground go from the sensor??
Is it possible to connect the brown cable from the zeitronix? That is I use the +5volt input in the dashdaq but the ground is not connected to the ground on the Dashdaq it is instead connected to the ground on the Zt-2.
If this is not ok, where should I connect the ground on the dashdaq, black or brown??
Need help fast, please
Old 07-23-2012 | 03:14 PM
Default Re: Dashdaq user input ground wiring, need urgent help
Rudy or Rob can probably help you here...but since you posted at 3 am our time. I am sure they haven't seen your post. You might PM one of them if you are stuck...good luck. I am tackling this project this coming weekend.
Old 07-28-2012 | 01:51 PM
Hi!
I have talked to Rob, it is ok to use the ground that is on the zt-2
aerobluehal1
Canada
19
10-13-2018 09:47 AM
Reliableron
10-17-2015 10:19 PM
2005 Ragtop
10-03-2015 03:01 PM
09-28-2015 07:40 PM
81's
09-13-2015 04:34 PM
Quick Reply: Dashdaq user input ground wiring, need urgent help
