SRT6 62mm Supercharger pulley??
  #121 (permalink)
Old 06-29-2012, 03:50 PM
32krazy!'s Avatar
Default Re: SRT6 62mm Supercharger pulley??
Originally Posted by FUBU
awesome data! I have the latest EC SC pulley (65mm) and it creates a lot of extra heat. Have you had longer trips with your car without having the front bumper to melt down?
if you think the 65mm creates a lot of heat try stacking it with a 178!!
  #122 (permalink)
Old 06-29-2012, 03:52 PM
[i was told that with anything beyond the 65mm pulley should have a Supercooler installed. I probably will get to this later in the year. Another thing i would like to get the AFR system needswings sells as well as the Waldig fuel kit.
I am just wondering if these should be done prior to the 62mm pulley or if i would be okay, just a bit hot. Again, they are on the list but im taking doing this piece by piece. already have the DCAI, tune, EC65mm pulley(soon to be for sale if this guy ever ships the item as i paid over 2 weeks ago).
  #123 (permalink)
Old 07-01-2012, 03:00 AM
rmaier's Avatar
my mods?
custom 3" DCAI
2 h/e's in serial
custom 3/4 wrap pulley set on the 62mm S/C for slippage
oil catch can
  #124 (permalink)
Old 07-01-2012, 03:03 AM
rmaier's Avatar
Sorry almost forgot 8mm magnacore wires and 1 step cooler +4 plugs
  #125 (permalink)
Old 07-01-2012, 07:13 AM
SparkieSRT6's Avatar
SSB SRT6 405hp/401Tq
Originally Posted by rmaier
my mods?
custom 3" DCAI
2 h/e's in serial
oil catch can
No tune ???
  #126 (permalink)
Old 07-01-2012, 11:01 AM
rmaier's Avatar
Yes a euro tune from Jerry
  #127 (permalink)
Old 07-01-2012, 07:15 PM
Any dyno? I'm curious to see what you get.
  #128 (permalink)
Old 07-02-2012, 10:17 AM
rmaier's Avatar
The dyno #'s are not what I would have expected. Lower than I would have liked to see given the better #'s I saw between the stock pulley and the change to the 65mm.
4th gear pull only netted 342 rwhp
My 65mm pulley with the same mods was at 328 rwhp
remember this is done at an altitude of 5382 so figure that along with humidity at 8% and 92 degrees F
29.64 bar and the adjusted rwhp would be 369
  #129 (permalink)
Old 07-02-2012, 01:00 PM
FUBU's Avatar
This means 20 rwhp increase with the 62mm from 65mm then I suppose?
  #130 (permalink)
Old 07-02-2012, 01:22 PM
JHM2K's Avatar
342 - 328 = 14...
Unless you're counting the hypothetical, sea-level adjusted horses.
  #131 (permalink)
Old 07-02-2012, 01:45 PM
dinasrt's Avatar
Originally Posted by JHM2K
342 - 328 = 14...
Based on his dyno results, and EC posted #'s for their pulleys and tune, I'm guessing that the new 62mm pulley exceeds a 185 crank pulley in horsepower, but probably a little less in torque than the 185.
  #132 (permalink)
FUBU's Avatar
342 - 328 = 14...
My excuse is that I have been playing basketball 3vs3 for about 2 1/2 hrs with pro ballers so I am knackered.
14 rwhp is correct
  #133 (permalink)
Old 07-03-2012, 07:17 PM
I put the new 62mm pulley on today and everything was going well until torquing the bolt holding on the pulley, SNAP, ****. I called a local chrysler dealership and they only could quote me for the ENTIRE ASSEMBLY for a couple THOUSAND! Mecedes is already closed. Anyone know where i can get a replacement bolt. I went to Napa and got one with the same thread and length so i could alteast get it home but im sure the strength is lower or atleast its not one with the hole to help cool running throughout.
  #134 (permalink)
Old 07-03-2012, 07:50 PM
dinasrt's Avatar
This should help you out. https://www.crossfireforum.org/forum...SC+pulley+bolt
  #135 (permalink)
Old 07-03-2012, 07:57 PM
grip grip's Avatar
I don't even attempt to reinstall the stock bolt when I'm changing out pulleys. I use a solid bolt from a hardware store for peace of mind.
  #136 (permalink)
Old 07-03-2012, 08:05 PM
The hole through the middle is not to keep it cool, it is so that it breaks after too much stress, bolts like this are often replaced after a single usage as they grow in length when tightened too much and are weaker as a result.
They act as the weak link in the chain and break to save other parts from damage. When torqued to the correct specs they stretch rather than add ever increasing clamp pressure on the bearing sides, too much pressure and the bearing will buckle and reduce the running clearance of the ***** and lead to early failure as a result.
You may have tightened it too much, the specified torque in this case may be too much for a solid bolt, the spec is for a hollow bolt and allowance is made for that in the torque spec.
  #137 (permalink)
Old 07-04-2012, 12:34 AM
rcompart's Avatar
Dave, sorry to correct you but this isn't true. Yes the bolt is a strech bolt and like pretty much every bolt on a benz, it's advised to replace it after it's been installed and then removed. This really has no correlation on the bolt being hollow as every other stretch bolt is solid. What that hole is there for is to keep the gear case pressure in the supercharger housing from blowing out the seals as the temp raises and the oil and resulting air inside the gear case expands. This is why there is a distinct smell from the front of the supercharger. And for the low torque rating of the bolt, it has nothing to do with the changing the clearances of the bearing, it's simply so you don't snap off the new bolt you put in. The same bearing is used in crown forklifts and is torqued town to 100nm which is almost 75 ft-lbs. I'm going to ask MikeR if he would make 20 or so of these for the guys on here because this will continue to happen more and more as these cars find new owners.
With how fast you're spinning that supercharger and the added heat you're creating, you more than most need the hollow bolt.
  #138 (permalink)
Old 07-04-2012, 01:55 AM
dinasrt's Avatar
If MikeR accepts and decides to make these, I'll take (2) please.
  #139 (permalink)
Old 07-04-2012, 02:21 AM
FUBU's Avatar
Gladly go for 2 myself aswell.
  #140 (permalink)
Old 07-04-2012, 02:49 AM
thanks for the adivce for now i got a NON-hollow bolt on it from napa simply so i can get around. gotta pull the computer this week and send it out so hopefully i can find it soon, if not i would gladly take two as well
Quick Reply: SRT6 62mm Supercharger pulley??
