replaced supercharger bearing
Re: replaced supercharger bearing
Mind you if it's made in China the previous statement may or may not be true.
Also check to see that the bolt/washer is centered when installed...if it is a bit offcenter it may make some noise.
Mine definitely makes noise until the ECT hits 185, then it goes away. I'm going to replace the bearing as well (again), just to see what happens.
I believe a lot of bearings are damaged from aggressive removal or installation of the pulley. If one bangs on the pulley to get it on the SC, the force can loosen the bearing housing. Pulleys should be installed / removed by hand (without tools) once the bolt is off.
I've taken it apart and put it together 3 times and its not getting better.... Any opinions?
It might be from something else, does it change with the clutch in or out?? Take a screwdriver and put the blade on the casing ( non moving part ) and listen at the handle with your ear pressed HARD so that you get conducted hearing -direct transmission of the sound(s).
Insanity: doing the same thing over and over again and expecting different results.
Albert Einstein
Albert Einstein
Honestly, this is exactly what I think my problem is...going to get it changed again and make sure they do it right...
leave the hammers in the tool box...rubber mallet maybe, no hammers. If you clean the surface properly, and maybe put the pulley in the freezer for awhile, it should slip right on. I haven't had to use the freezer trick yet, but have on other bearing installs on other equipment.
Freezing a bearing makes it smaller so it goes into a bore not onto a shaft, but you knew that, just a slip of the tongue so to speak.
Roty135
17
10-11-2018 10:11 AM
tom2112
10-26-2015 08:18 PM
cdcrone123
27
09-24-2015 11:28 AM
cdcrone123
08-04-2015 06:37 PM
