Sensor keeps popping out
Old 04-30-2012 | 05:53 PM
32krazy!'s Avatar
Default Re: Sensor keeps popping out
you were ......
Old 05-03-2012 | 08:57 PM
The Beep's Avatar
The IC pump is out. The SC works when the car is cold then quits when it warms up. I reseated the temp sensor but that didn't do anything.
I ordered a Bosch IC pump (oem design) from needswings. The original one lasted 10k miles. Hopefully this one will last longer.
The catch can still needs to be installed. That looks like a pita. I don't know how I'm going to get that hose in the back off. I'll pick a saturday and try to get them both done.
Old 05-03-2012 | 10:23 PM
Catch can isn't that bad...just take your time and follow the directions. IC pump is a little more work. If you remove the front bumper cover, everything is right there in front of you for the pump replacement, but it can be done without doing that.
Old 05-03-2012 | 11:40 PM
The Beep's Avatar
Remove the front cover??? Do not like the sound of that.
The instructions say to go through the RF wheel well.
Do you know what the wiring adaptor is for? Does it need to be soldered in?
Old 05-04-2012 | 06:05 AM
magredvet's Avatar
Brian, lets talk on Saturday, and I'll run you through it, or you can call round to my place sometime, and I'll help you. It's really no big deal, and can be done throughthe access hole in the fender liner. The fact you have an OEM pump makes it easier ........... :O)
Old 05-04-2012 | 09:18 AM
The Beep's Avatar
Is it ok to drive the car with the pump not working?
Old 05-04-2012 | 09:39 AM
magredvet's Avatar
Yup, it's just not fun !!!!!! ...........................
I'm at home this afternoon, if you want to get it done ?
Old 05-06-2012 | 07:24 AM
You can go thru the fender, I took the bumper cover off, to clean the front of the car, and the pump is just more exposed. It's not a big deal to take the bumper cover off either. I have done both cars more than once, and it is easier to work on things...
Old 05-10-2012 | 09:22 AM
JesseJamessrt6's Avatar
deleted duplication from seperate thread
Last edited by JesseJamessrt6; 05-10-2012 at 03:22 PM. Reason: posted seperate thread
rampntlion
21
02-11-2019 08:18 AM
eatmycrackers
09-23-2015 09:08 AM
caseydeankopp
09-13-2015 07:25 PM
bobbie
09-12-2015 12:49 PM
2004_
09-04-2015 01:39 PM
Quick Reply: Sensor keeps popping out
