Cheeper Rear Camber Kit!
Old 03-30-2012 | 12:48 PM
jevs's Avatar
Default Cheeper Rear Camber Kit!
I have been searching on here all day and finally found a cheaper solution for the rear camber when lowering the crossfire. Specialty Suspension Part Number 28840. basically like a KMAC, but different bushing materials.
Look at their website, as many placese do not list it for the Crossfire.
Specialty Products Company
Old 03-30-2012 | 01:00 PM
rmaier's Avatar
Default Re: Cheeper Rear Camber Kit!
Good find Jevs
Old 04-01-2012 | 12:17 PM
Buggin's Avatar
Wow, nice find! That is quite a bit cheaper! Installed my KMac set in the winter and need to find someone to do the alignment now so I can drive it...
Old 04-01-2012 | 01:08 PM
cheaper you say ???
I think MikeR's are the ones i am going with as they are made by a crossfire owner, and the ones here say most Mercedes,, 138x2 =$276.
mike's post with his PRICE
MikeR
- Forum Super Sponsor -
User Gallery
Re: Adjustable rear camber arms feeler... - 06-14-2011 , 10:00 AM
Guys, I am making these on order with the low volume and short turn time.. waiting for rod ends is the longest time and that is only 4-5 days.
Price is $225.00 + $14.50 shipping....
Old 04-01-2012 | 02:01 PM
Buggin's Avatar
Ah, I read that wrong. I thought "pair" meant a full set. Why would they be sold individually (per wheel)? That is just dumb...
Old 04-01-2012 | 04:55 PM
maxcichon's Avatar
And $91 for the press kit...
Old 04-01-2012 | 09:28 PM
jevs's Avatar
I'm pretty sure it is one bushing for each side in the kit. I have a press and a KMAC tool, so I don't think I will need their tool. It looks like the guy I bought from on eBay raised the price though. I paid $66 shipped. Now it is over $80.
Old 04-02-2012 | 01:05 PM
Buggin's Avatar
Default Re: Cheaper Rear Camber Kit!
It requires 2-bushings per side as it's a 2-pc setup (same as KMAC). If you read that site you listed, it specifically says that 1 "set" is for 1-wheel. FWIW, the KMAC bushing removal tool is junk. It's supposed to be used with an impact wrench to pull the old bushing out. I tried many times, and it was clear that this method would not work. I finally used a press and a spare chunk of stock to push/rip the center out of the old bushing, then a hacksaw to split the old bushing's sleeve... and then a chisel to get the sleeve out. Much more work than I had originally thought. Good Luck!
Old 04-02-2012 | 01:49 PM
jevs's Avatar
Yes. I see now that you need to order 2. I only read the eBay add and called the company to confirm it will work. I was thinking it was a single bushing per side for a single link arm like the other car I just did (KMAC for Audi). I never even looked at my suspension yet. So, I just ordered another one at Amazon.com for $69.44 (free shipping). Total cost for 2 was $135.65. Still cheeper than any other option that I have found. If the bushings are a big pain I can always blow them out with the torch, but I have a 20 ton press. Also, if the KMAC tool is junk (last one I used on the Audi worked fine), then that is more reason not to pay nearly triple price.
Old 04-02-2012 | 05:25 PM
Buggin's Avatar
Based on that Amazon price, they are a great deal. I tryed torching one(which didn't work too well) and finally threw it in a 40-ton aircraft press at work. A 20-ton should work fine though. The tricky part is to keep it perpendicular so the press goes though it straight and not gouge the walls. Please let us know how they work out. I know a lot of people complained about the poly KMACs squeeking. These look more like the OEM rubber, so might be quieter.
Old 04-02-2012 | 05:47 PM
hcarter's Avatar
I will concur the K-mack press kit is total Sh*5 it's junk and poor design but the bushings are top quality and i have zero squeaking or noise , and even at the low price of the kit you purchased after you get thru cussing and fussing while trying to install ,you would have been better off buying Mikes and having them installed in 30 minutes , just IMO , Each owner will alway travel their own path and I wish you success and please share your experence with us after the install... Happy motoring
Howard.
Old 04-02-2012 | 05:51 PM
MikeR's Avatar
and after you buy the two sets and the tool.... you will have spent a few dollars more than mine....
It's too bad they dont make a set for the FRONT...
as mentioned.... let us know how they work out...
Old 04-02-2012 | 10:15 PM
jevs's Avatar
Im not buying any tool, so $138 is all I am spending. I'm not sure why you guys keep blabbing on about the stupid tool
I will report back after the install for those interested.
Old 12-20-2013 | 04:11 PM
mobilefitt's Avatar
I need to know if I need a camber kit for Eibiach Pro Kit. 1.2inch drop fronts, 1.3 drop Rears.
Old 12-20-2013 | 06:00 PM
You should. Dropping it about an inch will require 1 degree Camber correction. The camber kits are available at Needswings, unless you know how to make your own.
usprb1976
04-04-2024 04:57 PM
Jonacross
20
07-17-2017 11:19 PM
Posimoto
09-13-2015 06:13 PM
Big Daddy
09-10-2015 10:21 PM
jaesa
09-07-2015 01:50 PM
Quick Reply: Cheeper Rear Camber Kit!
