TCU and Rev Limiter
Re: TCU and Rev Limiter
Originally Posted by BushPilot
So they are fixing the TCU by lowering the shift point back to stock (6200)? I like the way it shifts at 6500 or so as it really screams in that range. Just don't like the thud.
the thud you feel is the tps slamming the t/b shut from 98% to 8% and then openoing it fully again. thats were the afr spike occurs
I had the Eurocharge tune at the Crossfires Across America GTG in St. Louis in 2010.
Red line seemed to be raised to 6200.
I've been autocrossing before and after the tune and don't recall any of the gears hanging up before shifting. All shifts have been smooth and without delays at redline.
Thanks for the correction/information. Is the TCU for Torque control?
Originally Posted by 32krazy!
the idea is to allow for faster shifting via the amg speedshift pkg, allow the trans to hold a specific gear at redline vs the tcu upshifting automatically and raisng the torque limiters to 1000 newtons so the tcu wont go into limp mode during hard high hp shifts. in summer mode the trans acts as oem in winter mod it becomes a full manual shift
He directly in to 2nd gear?
Originally Posted by FUBU
For us actually using the oem winter mode, if doing this mid I suppose the winter mode is going to be bad for driving in 2 meters of snow? or can I VHS
Thanks 32, this conversation, very quickly, went over my head.
I do remember that after my tune, Jake had to either remove or raise the torque limit on my car because the car completely shut down for a moment during hard acceleration on an on ramp, and I mean Completely.
Hehe, this may be my only contribution to this conversation. Sorry guys, I tried.
also the data shows the power curve falls off after 6200 slightly
I took the 6 out to the track this past Friday night so I could datalog and made only two passes. I removed/reversed all mods I did AFTER the TCU tune to see if any gains were made just from TCU mod. I logged the 1st pass and hit rev limiter in 2/3 and 3/4 shift and second pass I forgot to log and hit limiter again but with a loud "pop" sound.......almost like backfiring through intake........and now I am done with this mod. I also ran slower than ever and in great weather managed a best of 12.3@115. I won't race again until I get my TCU returned to stock as it's not worth potentially blowing my engine..........and running slower at the track.
i have the latest tune from jerry. i have datalogged and theyare finally on the right track. the setup is now ecu 6500 rpm, tcu 6200 rpm and torque limiters set at 1000 newtons. this allows for easy smooth shifting in D no different than oem. in summer with manual selection the shifts are quick and firm with no afr spikes and zero lag. is it faster than oem? i cant say. i have had so many tcvu mods tried i forget what it was like oem. the only thing i found was that in w mode the tcu still shifts at redline doesnt hold the gear like i thought it should.
Originally Posted by jesserettele
Is EC going to make this standard on their tunes for the tcu or will this be an option to request?
was any body able to increase the limit of the rpm?
originally set to 6250rpm.
i already installed a tcu tune from eurocharged, which promised an rpm limit rase.
but this did not happen.
the car now cutts off with a loud noise, then shifts after that at 6250rpm.
this is making me much slower.
i thought it is an ecu problem, i installed a viezu tune (from england) to just raise the rpm.
nothing happened, the car still shifts after lound cutoff at 6250.
note before tcu tune from eurocharged the car shifts smoothly at 6250 rpm without cutoff.
thank you
thank you
check out this, they have eurocharged TCU problems too
hitting rev limiter after tcu tune - MBWorld.org Forums
thank you
thank you
I am very disappointed in the TCU tune. After having been burned by being a beta tester by being an early adopter I did not jump on the TCU tune when it was first offered. I am glad I waited but had high hopes for it. Would have been great if it worked out as promised.
