VIDEO: EC SC Pulley installed
Re: VIDEO: EC SC Pulley installed
Originally Posted by rmaier
Bad bearings? I don't have enough miles on the new engine transplant to know the draw backs for the stock sc pulley but if the bearings are a bad design then I may want to go with a diff pulley. I am sure something out there is similar.
Originally Posted by 32krazy!
not knocking your setup at all. a suggestion is replace the oem idler you moved with a 90 mm napa pulley. go to 100 mm if you cant find the 90. the oem tiny pulley sucks eggs and i replaced 3 within a yr.
Howard, the drawing I posted shows the part numbers.... here is the 90mm at rockauto.com
GATES Part # 38001
GATES Part # 38001
tom2112
10-26-2015 08:18 PM
07-24-2015 07:57 PM
