Stacked pulleys - 23 psi with no codes. :)
Re: Stacked pulleys - 23psi with no codes. :)
Originally Posted by 32krazy!
right off the bat the oem are 480 cc injectors these are 550cc injectors. the TTM also have a dual spray pattern that replicates as close to a direct injection spray as possible. they also use the oem retaining clips whih other injectors dont use. this allows the injector to be held in place with the clips and not just the 4 bolts holding the rail in place
Originally Posted by Lenin
Is it 550cc flow at 3 bars PSI? The rest is a little confusing. The 1130780123 is an updated OEM injector. Don't they also have a dual spray pattern and the oem clips?
Originally Posted by 70GS455
No, the 550cc is at 55 psi. At 3-bar it's more like 480cc/min (stock is like 410cc at 3bar)
The TTM fuel injectors and adapters arrived today. Bruce even included a couple pens.
Eurocharged is scheduled to retune me (remotely) on Friday.
Any update on how you have made out with the injector install and retune ??
Re: Stacked pulleys - 23 psi with no codes. :)
I sold the mid pulley and I'm having a new pulley machined this week. I really want to stick with my original plan of running 22psi (not 23). After the pulley is completed and installed, I'll get a retune to see if the stock injectors and SL55 fuel pump will keep up.
If I'm still lean at that point, I plan to install a larger fuel pump. I really don't want to install larger injectors if I can help it.
Good luck.
I take it that the new pulley will be turned down slightly less than the first one?
Good luck.
Good luck.
5MM = 3 psi
1MM = .6 psi
3.33MM = 2 psi
I finally got the 2psi (-3.33MM) pulley back from the machine shop (Bullard). This time they only charged me $140, since they are making quick work of it now.
I bolted it on and drove a few miles today to make sure it was engaging properly and not making any noise. The power is great and my new tires are getting it to the ground without excessive spin.
Tomorrow, barring a rainstorm (which is in the forecast), I'll datalog 2nd, then 3rd gear to see where the timing, fuel, and IAT's are.
After that I'll get a retune if I'm lean up top.
I should know this but, what intercooler pump do you have? My additional heat exchanger experiment isn't working out but I have the stock weak-a@@ pump. The knock on higher boost has always been the extra heat, as you know. Do you have the thermal coated I/C? I WANT ONE! I'm taking notes in case you didn't notice.
Les
Les
Les
Les
I'm running the CM30. As for the I/C, it isn't wrapped yet, but that's on the list.
on
Les
Les
I hope you get the stacked pulleys to work, you'd be the first.
And I thought I was first!? Been stacked for over 3 years now.
Of course there was that one little incident! (see towards bottom of thread)
https://www.crossfireforum.org/forum...tml#post536510
Originally Posted by tighed1
https://www.crossfireforum.org/forum...t-happens.html
I'm definitely not the first with a stacked setup, but I suspect I might one of a few hitting 22/23psi at sea level.
I'm back to running lean. If a retune does't correct it, I'll have some hard decisions to make.
So if retune does'nt correct it what are the options......injectors, back to stock pulley, what else ?? Just curious.
adj fuel press regulator, larger fuel filter w/ built in regulator, bigger fuel pump, looped fuel line, injectors all coupled with retunes come to mind
