Eurocharged SC Pulley results
Re: Eurocharged SC Pulley results
Originally Posted by itsky
I got the tune done today. Super-permagrin is all I can say.
After Eurocharged Supercharger Pulley and Tune - YouTube
were you on the dyno? what did it make? mods?
WE HAVE CREATED A MONSTER....Evan, calm down son, it will only get better the more mods you bolt on. You are just getting started. It is an addiction, and we will soon have enough to open our own chapter to seek help for this addiction. I am filling out insurance enrollment forms this morning, and I think I am covered.
Originally Posted by FUBU
Nice car! Mine was just like it, blue Sounds great and a lot now with the pulley. I will install mine in end march with tune and dcai. How is the starts now? Can you push the throttle or is it wheel spin into 3rd?Enjoy the beauty
Originally Posted by velociabstract
Whoa! The tensioner is spring loaded and you don't loosen the bolt. You pull it counter clockwise to release the tension on the belt. I used an E10 socket.
Les
Les
Les
Les
Edit:
Got the pulley on but I think I may need a shim. It is very close and i'm pretty sure it is touching in one very small area. Guess I'll have to wait a few days to finish.
Originally Posted by linstr63
Edit:
I see that this has turned into a little bit of results-based discussion. I'm going to do the EC SC Pulley and Tune soon too. I'l probably do a coolant separation soon as well.
Question is, is a larger Intercooler a must with this mod? I plan to drive on the streets mainly for leisure. I'll likely go to the track once or twice a year for a couple runs on a test and tune with my roadster. Just wondering if I should do cooling before I do the pulley and tune.
linstr63- start the car and let it run a bit. The pullies typically will straighten themselves out without need for additional shims.
on
I was just checking out the EC website, and the image posted for the SC pulley appears to be different from the one that was sent to those in the first batch that were produced. Is this the version II of your SC pulley? The rivets and spring bars are different from the first batch sent out. Eurocharged C32/SLK AMG Supercharger Pulley
