Eurocharged SC Pulley results
Re: Eurocharged SC Pulley results
Originally Posted by rmaier
Itsky have you got your's all tuned up? I have a scan gauge running on mine and with the dual 3" CIA the magnacore wires and colder plugs with the pulley and tune I am seeing 426hp! That of course is not a true "dyno" but it is the same concept and measurements of potential so close.
Originally Posted by jsaredwings
i believe i have read on here that the srt6(STOCK) dynos around 280ish at the wheels. 427 seems too high, maybe low 400's off the engine but by the time u get the power to the wheels its more like 360
My guesstimate was based on it being around 340whp, which is possible assuming about 50whp gain from the pulley and tune on a 290whp car, which gives 425bhp. This may be more or less due to slight engine variances. I just said 427 because I like that number.
Originally Posted by itsky
I am still having issues with the metal plate on the pulley not staying flat causing an odd rubbing noise. Until that is resolved, I won't be driving it too hard.
Glad you figured it out...they aren't perfectly flat. You just have to shim to the correct fitment, and use it...tune will bring her home...then...hang on..your low end will be really noticeable, but after the tune, she should pull even harder on the higher end...good luck...
Glad to hear the good news....Jerry ROCKS he knows his stuff as does all the guy's at eurocharged. You will be wearing a perm-a-grin from now on Evan.
Too true too true you had 1 pasted at the last GTG in Garden of the Gods run......amazing what a little S/C does to these cars. Now it is really awake with the new pulley and the tune will amaze you again......I am sure there is a law against this much fun ......but ignorance is BLISS!!!
One additional mod I will need is a decent set of rear tires. The Hankook's that are on there now just can't handle it. Or is this just a common occurrence with SRT-6s?
I got the tune done today. Super-permagrin is all I can say.
After Eurocharged Supercharger Pulley and Tune - YouTube
