SL 55 AMG pump
SL 55 AMG pump
This appears to be the SL 55 AMG pump:
New TI / Walbro Twin-screw Fuel Pump - TurboBuick.Com
This is either the TI-Walbro version of the pump or its the TI-Pierburg pump repackaged (TI owns both).
If so, its a good price.
Re: SL 55 AMG pump
If you want to replace it because you feel you may have a fuel supply volume problem, you can determine this by connecting a fuel pressure gauge to the rail and attaching it (duct tape works lol) to the windshield. This way you can monitor fuel pressure from the cockpit under worst demand (WOT) conditions and look for fuel pressure dropping below the regulator set point (even if you've modified that).
Re: SL 55 AMG pump
I have a pressure sensor on my fuel rail and a Zeitronix/Dashdaq to monitor fuel pressure.... mine is adjusted(NW fuel kit) to 62psi and at WOT I see the rail pressure drop to about 48psi while sucking down gas..very interesting to look a the data log of the fuel pressure across a run....
Re: SL 55 AMG pump
Sounds like you may have a fuel supply issue...the pump isn't keeping up with the demand. The regulator tries to maintain pressure by returning excess fuel back to the tank. When there is no excess, the regulator is closed off and the total volume of fuel is going out the injectors. When the injectors flow more fuel than the pump is supplying, pressure drops.
These constant-power pumps will supply more fuel volume at lower pressures, since it is fighting less against the head pressure. A possible solution (if lean) would be to lower the pressure, and increase injector pulse-width at WOT if possible. Unless there is no more inj pw and they are static, then the solution is more pressure (and possibly bigger pump).
Dropping fuel pressure is not always an issue. When the pressure is high at low-demand conditions, the PCM just dials back inj pw. At WOT, if inj pw is large enough and fuel pressure drops to a level sufficient enough to maintain AFR, then it's ok. However, almost always, there is no safety margin if the need for more fuel (hot day, bad gas, high boost, etc) suddenly arises.
Re: SL 55 AMG pump
Ive done lots of testing and adjusted my rail from 40 to 80+ PGIG. If your lean, jack up the rail pressure a few pounds. I got the fuel controller working with the Zeitronix open loop pressure controller and solved any leaning tendancy. The increasing boost pressure limits the EFFECTIVE pressure across the injector pintel reducing your fuel DELIVERY when you need it most. THis is why I cautioned that the pump must be rated to OPERATE at about 60 or a bit better. Wooody
Re: SL 55 AMG pump
