burned out light warning
Re: burned out light warning
Originally Posted by atlsrt44
When I turned on my headlights today when it started raining the burned out light warning light came on. When I parked I looked and all my lights were on even parking lights. When I went to leave the warning light wasnt on anymore.
Anyone had that happen before?
Also as stated above many forget the two plate lights in the bulb count.
Hopefully you guys didn't get the SLK intermittant bulb holders... Mine is always the right rear running light. The tabs on the sockets start to loosen and make intermittant contact. If not caught early, the plastic starts to melt. Mercedes had a TSB on them and even though I had mine replaced under the recall with the new style, they are doing the same thing...
Keep in mind this is the Benz SLK I'm speaking about, just figured you can check them to see if you got another one of our "known problems"...
Kodebuster
11-05-2020 04:06 PM
KwehCat
07-16-2015 04:48 PM
