Driveshaft removal
Re: Driveshaft removal
The SRT repair manual in the Documentation section does an ok job explaining it. The manual says you need a gear pulled to get the old support bearing off and a press to put the new one on.
I am also curious if anyone has tips/tricks for this, as I will be changing mine soon also.
Originally Posted by svtcobra
does any one know the steps to taking the driveshaft out and replacing the driveshaft support bearing
As stated above, check out the documentation. Good luck.
Did you ever get around to doing this? I'll be tackling mine in a few weeks when I get back into town.
I keep reading the service manual and it talks about supporting the transmission and removing the trans mount brace and then the front flex disk to flange bolts... I didn't see that in Rob's post.
×Crossfire1× (05-07-2024)
o55ie18
10-05-2015 05:50 PM
55chevy
09-13-2015 07:38 PM
