5w-40 oil
Old 03-16-2011 | 08:59 AM
noles's Avatar
Default 5w-40 oil
I went to the Mercedes dealership and picked up a filter (which was about $10 cheaper than Chrysler) and the guy asked me what kind of oil I was putting in there. I told him, and he said Mercedes now uses 5w-40 in everything except the SLR. It still uses 0w-40. Did anyone already comes across this? I'm going to call Chrysler just to see if they have switched as well
Old 03-16-2011 | 10:52 AM
DTMenace's Avatar
Default Re: 5w-40 oil
I usually get my SRT6 serviced at my local MB Dealer and for the past two years, they've used the 5W40 when doing my oil changes. I see no difference in performance and it appears to perform as prior to the new oil weight.
Dennis
DTMenace
Old 03-16-2011 | 11:27 AM
noles's Avatar
Now I'm confused...I just spoke with my friend, who is a Merc tech in Baton Rouge and he says that they still use 0w-40 and only use 5w-40 in their diesel cars...I'm not sure what to think. I guess you can use both.
Old 03-16-2011 | 12:41 PM
Bladecutter's Avatar
The car doesn't need a specific weight of oil, it needs an oil that meets the MB 229.3 or 229.5 oil specs.
Oil weights that meet this spec vary:
0W-40 is very popular with Mobil 1.
5W-40 is second most popular, with Pennzoil Ultra, Castrol Syntec and Valvoline SynPower having Euro formulas.
There are even 5W-30 and 0W-30 versions available from Castrol that meet these specs.
The individual dealers are allowed to order whatever oil they want from their distributors. Some just buy Mobil 1, and use that. Others buy Pennzoil or Castrol and put that into your engines.
All of it works just as well as everything else.
BC.
The following 2 users liked this post by Bladecutter:
kowaltoboggan (12-15-2021), sandratoddtx@icloud.com (05-07-2024)
Old 03-16-2011 | 01:34 PM
6000rpm's Avatar
You're right, BC. I'm using Castrol Syntec 0W-30, European Formula. On the back of the bottle it says it's approved for MB 229.1, 229.3 and 229.5.
Tom
Old 03-16-2011 | 01:58 PM
BC.
I agree, oil is oil and as long as it is good oil you would not notice any difference in the short term. Long term may be another story with sludge etc.
Anyone who says he/she can feel a seat of pants change is probably fooling themselves.
Using a totally inappropriate oil is a different story.
Old 03-16-2011 | 02:16 PM
I go by the MB 229.3 / 229.5 designators. Now, I have only found those designators on 0W40 and a few 5W30/40's.
From what I've seen on MB's tech website, Mobile 1 0W40 actually provides better high temp viscosity than any other oil - so I'm sticking with it.
Old 03-16-2011 | 02:40 PM
Mimi05SRT6's Avatar
I've only been using the Amsoil 5w-40 in my Crossfire, no complaints here.
Old 03-16-2011 | 03:43 PM
Goldwing's Avatar
BC, good information. I just went to my garage and the Mobil1 0w-40 is MB-229.5 while the Mobil1 0w-30 (green cap) is not. Anyone know the difference other than the lower viscosity when cold? I'm pretty sure that since I don't race these and change the oil annually (usually with 3-5k miles on it), I doubt I am at risk for sludge or damage.
Old 03-16-2011 | 03:47 PM
noles's Avatar
I would probably like to stick with the 0w-40 but I work at a dealership and can get the 5w-40 for free...So today I'm putting in 5w-40
Old 03-16-2011 | 05:01 PM
SRT6_Roadster's Avatar
Tom
Castrol Syntec is not a true synthetic oil. You are much better off running Mobile 1 or pretty much any other oil.
Personally I would not run Syntec in any vehicle.
Old 03-16-2011 | 08:30 PM
ZAHANMA's Avatar
I just got a nice hookup with some Royal Purple 0W-40 through my dad. His chemical plant uses only royal purple for its lubricants. I needed to change the oil and I'm getting it at wholesale. Can't argue with that. Perfect timing.
Old 03-16-2011 | 08:38 PM
arado's Avatar
I am now using 10/40 Mobil 1. Made for Diesel. More Zinc. my cost is $20 for a four qt. Bottle. I have full confidence in it. Gary
Old 03-16-2011 | 09:25 PM
mdaniels4's Avatar
I agree. Oil is oil for the most part. here in MN, I'd be using 0-40 all the time IF i was running the car daily in the winter which I'm not. The thinner oil in the cold temps, combined with the tight tolerances is a good thing IMO over the long haul. So having said that, and we have wild higher temp swings up here, I'm absolutely not concerned one way or the other for using 5W-40 for my use, because I run it maybe for 15 minutes a month in the winter, but all the time in the summer, and the slightly thicker oil is IMO better for the car, and the 40 has a better range all around. next year, and I only do 1 change a year, 6-8K a year, will be the 5W, but of course full syn.
Old 03-17-2011 | 04:45 PM
Castrol and Mobil had a discussion about this many many years ago, and the end result was that Castrol IS synthetic engine oil.
Plus, there are a few different versions of Castrol's Syntec oil now a days.
I'm talking about the German Castrol 0W-30, and the Syntec 5W-40 versions, both of which meet MB's specs, and should be fairly easy to get ahold of at your local auto parts store.
Personally, I prefer to put Valvoline, Shell or Pennzoil in the vehicles I have under my care over Castrol or Mobil. The Ducati's get something even more special.
BC.
Old 03-17-2011 | 05:24 PM
Erichenderson02's Avatar
Old 03-17-2011 | 06:20 PM
WOW! I didn't remember the lists being that LONG. (But so many of them are available in only selected regions... Just TRY getting Mobile 1 5W50 anywhere!)
Old 03-17-2011 | 06:28 PM
There was a lawsuit over the term Synthetic oil and castrol won on based on the argument that it was a marketing term. If you look at the PAO groups used to form each oil you will see there is a difference in quality between Syntec and Mobile1. Not trying to imply that Mobile 1 is the best oil out there just that it is significantly better than Syntec.
If you have questions on oil I recommend heading over to Bobistheoilguy.com
Old 03-17-2011 | 09:39 PM
Display_Name's Avatar
(Warning: Pedantic post follows.)
Complicating this for SRT-6 owners who want to follow the rules that come with engines' AMG construction and history, not every oil that is 229.3 and/or 229.5 is acceptable for use in an AMG powerplant.
Mercedes-Benz recommends only the use of Mercedes-Benz approved synthetic motor oil for all vehicles equipped with the Flexible Service System (1998 & newer). Below is a List of Mercedes Approved Synthetic Engine Oil (1998 – 2004 Models):
  • Mobil 1 SuperSyn European Car Formula 0W-40 | MB Sheet: 229.5
  • Castrol Syntec European Formula 0W-30* | MB Sheet: 229.5
  • Pennzoil European Formula Ultra 5W-30* | MB Sheet: 229.5
  • Quaker State European Formula Ultra 5W-30* | MB Sheet: 229.5
  • ELF Excellium 229.5 5W-30* | MB Sheet: 229.5
  • Mobil 1 ESP Formula M 5W-40 | MB Sheet: 229.5
  • Mobil 1 SuperSyn European Car Formula 0W-40 | MB Sheet: 229.3
  • Castrol Syntec 5W-40 | MB Sheet: 229.3
  • ELF Excellium LDX 5W-40 | MB Sheet: 229.3
  • ELF Excellium LDX 0W-30* | MB Sheet: 229.3
  • Quaker State Full Synthetic European Formula 5W-40 | MB Sheet: 229.3
  • Pennzoil Synthetic European Formula 5W-40 | MB Sheet: 229.3
  • 76 Pure Synthetic Motor Oil 5W-40 | MB Sheet: 229.3
  • Kendall GT-1 Full Synthetic Motor Oil 5W-40 | MB Sheet: 229.3
  • Motul 8100 E-Tech 0W-40 | MB Sheet: 229.3
  • Motul 8100 X-Cess 5W-40 | MB Sheet: 229.3
  • Shell Helix Ultra 5W-30* | MB Sheet: 229.3
  • Shell Helix Ultra 5W-40 | MB Sheet: 229.3
  • Valvoline SynPower MXL 0W-30*| MB Sheet: 229.3
* Not approved for use in AMG engines.
Mercedes-Benz Approved Engine Oils AMG Market | AMG Mercedes-Benz Enthusiasts
SRT-6 engine uses older style C32/SLK32 service system so the data from '98 to '04 applies.
Will you cause problems using an approved for MB but not approved for AMG oil? Probably not, but given that it doesn't cost much more to go with an approved oil, there isn't much reason to not choose one without an asterisk.
Also note this warning about the low ash oil (ESP 5W40 M1 designed for diesels.)
0W40 was the only recommended weight until 2007, when a special 5W40 low-ash oil became mandatory for the Bluetec diesels with urea injection. In order to simplify stocking, MB updated the sheet to allow the 5W40 low-ash for gasoline engines as well. For a short while, dealers were using this in all engines. But some problems arose, and almost all dealers now stock both oils, using the 0W40 in gasoline engines and 5W40 low-ash in diesels.
I would stick with the 0W40 for all gasoline engines.
5W40 or 0W40 MOBIL 1 - MBWorld.org Forums
The following 2 users liked this post by Display_Name:
kowaltoboggan (12-15-2021), XFire613 (08-14-2022)
Old 03-17-2011 | 10:25 PM
noles's Avatar
Thanks for the info
Quick Reply: 5w-40 oil
