Eibach pro Kit SRT 6
Re: Eibach pro Kit SRT 6
Originally Posted by velociabstract
That picture does scream progressive but the springs in that picture do not come in the Eibach box for the Crossfire. The Eibach's for the Crossfire are longer than the stock springs. The coils on the stock springs are closer together than the Eibach's or if you like, the coils on the Eibach's are wider apart than the stock SRT springs. At least that's the way I remember it. I have the Eibachs in the box and can take a picture if necessary.
Les
Les
My recent thinking is I somehow got a bad set from Eibach. For that reason mine won't go up for sale, or if they do, it will be more or less a gift.
Les
Les
https://www.crossfireforum.org/forum...ted-my-xf.html
I have the Eibach Pro kit and, although they seem a hair longer, the car did drop about an inch and a half. Also the stiffness of the ride did not seem to change much at all. The only problem I have is my front camber is a little off leading to excessive wear on the inside of the tire. I've been told that it is an easy fix, adding a spacer, but I'm not a suspension expert so I'm not sure if it will really be that easy.
Question:
Does the SRT-6 come already lowered from the factory?
I know that on the SLK32, it comes from MB lowered. The height of the SLK32 is the same as a SLK230/320 with the Eibach Pro Kit installed.
Actually, the springs themselves on the SLK32 has both AMG and Eibach logos on them. I noticed this the last time my car was up on the lift at my indy.
I guess my question is, I know the two cars are practically identical under the skin, but does anyone know if the suspension different between the 32 and SRT6? If the two cars use the same springs, then I am wondering if the Eibach Pro Kit will lower my 32 even further?
FYI,
The Eibach pro kit springs are softer than the OEM. They are close to equalling the Crossfire Limited models which are near 50% softer than the SRT's.
Also, to do any suspension modifications properly you must look at the whole geometry of the suspension as well. Camber and castor adjustments are manditory.
There is a very good reason why most suspension modifications worsen the cars handling and most of them stem from doing things half assed.
Manufacturers spend hundreds of hours of R&D to make their cars perform at the highest levels. To think that a inexpensive after market part can make things better than the original is truly wishfull thinking.
If looks are the only thing that you are interested in then yes, lower your car. But if superior handling is what you are after then you either keep the original set up or you go to a professional road race shop and have them do the modifications.
With this level of car, driving enjoyment should be your first priority.
Good luck.
Good luck.
maxcichon
04-21-2021 08:29 AM
Kodebuster
11-05-2020 04:06 PM
turboomni08
07-07-2015 11:48 AM
