Help...High Pitched Sound
Old 12-12-2010 | 04:34 AM
simmie777's Avatar
Default Help...High Pitched Sound
Finally got my SRT-6 Roadster!!!! But a few days ago I noticed a high pitched sound coming from my car. It sounds like its coming from behind the right front headlight. Could anyone help with the diagnosis, before I take it to the dealership??
http://www.youtube.com/watch?v=FpMoYZ4OnBs
Old 12-13-2010 | 01:12 PM
Goldwing's Avatar
Default Re: Help...High Pitched Sound
The only high pitched sound I have is my wife screaming at me to slow down.
Old 12-13-2010 | 01:19 PM
tri_zombie's Avatar
I'm not able to pull up youtube currently but I believe your are hearing the bosch pump for the heat exchanger.
Old 12-13-2010 | 06:33 PM
simmie777's Avatar
You can usually fix high pithced wife sound with chocolate or jewellery :-)
Old 12-13-2010 | 06:42 PM
simmie777's Avatar
I thought it may be the IC pump?
Old 12-13-2010 | 07:01 PM
Wedge's Avatar
When my IC pump was failing there was no sound involved.
Hopefully others will chime in here.
Old 12-13-2010 | 07:51 PM
Same here. I've never seen anyone say it was making a noise when it went out.
What speed do you hear the noise?
Old 12-13-2010 | 08:08 PM
MikeBrink28's Avatar
You definitely need to give more information. Is it a constant sound? Only under hard acceleration?
Old 12-13-2010 | 08:09 PM
simmie777's Avatar
I can hear the noise even at idle. At first I thought it was the fuel pump, until I noticed it was coming from the very front of the car. In the youtube clip I am at idle in my garage (which makes it sound even worse!).
robby363's Avatar
It could be the other coolant circulation pump. It's located between the right headlight and radiator. It looks just like the ic pump. It Is for the rest.(Residual engine heat utilization)
Old 12-13-2010 | 08:10 PM
simmie777's Avatar
The noise is constant, unfortunately.
Old 12-13-2010 | 08:21 PM
simmie777's Avatar
Thanks mate, I will check this out and see if I can find a part no. for it somewhere.
Old 12-13-2010 | 08:33 PM
Squirrel Crusher's Avatar
I usually find odd sounds by putting a small diameter, 3 foot long hose to my ear. Using the other end as a stethoscope. Squirrel Crusher
robby363's Avatar
This is the part# 5098398AA
Old 12-13-2010 | 08:38 PM
robby363's Avatar
It does sound more like it could be the alternator or water pump.
Old 12-13-2010 | 08:44 PM
I noticed than pump while I was changing out the IC pump. Haven't heard of anyone's going out yet. I guess when it does,the engine will quickly over heat. Squirrel Crusher
Old 12-13-2010 | 08:51 PM
simmie777's Avatar
If it helps, the sound doesn't happen immediately when I turn on the car. Usually starts after about 30 secs or so.
Old 12-13-2010 | 09:01 PM
simmie777's Avatar
oh, and gets progressively worse.
Old 12-14-2010 | 12:21 AM
cruzinquick's Avatar
open your hood and eliminate any chance it's coming from your engine compartment. sounds like a pulley bearing to me.
Old 12-14-2010 | 10:24 AM
tunaglove's Avatar
I say IC pump with squealing bearings.
