Air Pump Problem - (common)?
Old 12-04-2010 | 10:21 AM
Default Re: Air Pump Problem - (common)?
Originally Posted by tighed1
Believe this is what you are up against.
Sounds like the contacts stuck together.
If I could get folks to send me their bad RCM's I could start switching out the Air Pump relay with other relays on the RCM.
Surely the simple and cheapest way to fix these is to change the relay. A little unsolder tape, take out the faulty one and put in a new relay.
Switching relays from one to another means that new or re-cycled RCM's are required.
Relays cost around $10 to $15 each generally and they are made to standards so they are interchangeable.
Old 12-04-2010 | 10:29 AM
DJ...I'm having a new garage door installed, so I have to have the pair running, but as soon as the door is up, and they are back in...I am going to pull both RCM's...take a look at them....may just send them both for your repair...good time to do it...
Old 12-05-2010 | 12:14 AM
tighed1's Avatar
Anyone got a part number and source on a replacement relay we can use?
Yo Doc.
Send 'em!
Old 12-08-2010 | 11:14 AM
Steve Hellums's Avatar
I'm sure you are right. I pulled the RCM out of my other SRT-6 & put in it and cured the problem. There is also a smell of power steering fluid or tranny fluid since I bought it, then the drivers heated seat quit working yesterday. So I decided to use my Maxi-Care $100 deductable warranty & get a 3 for 1 deal, I had Chrysler order the bottom seat cover & RCM yesterday. I wanted to pull the old RCM apart to look at it, but they told me not to or it could void my warranty.
Old 12-08-2010 | 12:58 PM
MikeR's Avatar
Good deal Steve....a 3 fer is always a good thing.....
Old 12-08-2010 | 02:34 PM
I was glad the heated seat quit working yesterday. Jeff is a pretty good size guy and the seat bottom was wore real bad from him getting in & out. Plus I don't have to take the belly pan off to see where the fluid smell is coming from.
Old 12-08-2010 | 05:44 PM
So you are saying he may have crushed the elements.....lol....
Old 12-08-2010 | 08:23 PM
32krazy!'s Avatar
if its possible can you see if the dealership will let you have the bad rcm when they replace it. dj could use it
Old 09-16-2014 | 02:10 PM
martyfa's Avatar
Will this work?
AZ970E-1A-12D American Zettler | Power Relays (20 Amps to 99.9 Amps)
Old 09-17-2014 | 10:05 AM
tighed1's Avatar
That's the one.
PNA
11-12-2020 04:44 PM
gblack32
09-07-2016 08:27 PM
chturner
07-24-2015 04:47 PM
Beeker
07-20-2015 03:46 PM
ja.nko
07-10-2015 03:21 PM
Quick Reply: Air Pump Problem - (common)?
