Temp sensor and thermostat location???
Old 11-05-2010 | 08:34 PM
srt6vic's Avatar
Default Temp sensor and thermostat location???
I recently got me a 2005 srt6, to make a long story short car has 37000 miles and runs great, the engine light went on and I had it scanned and the code that came up could be the coolant temp sensor or the thermostat.
Can somebody tell me where they are located? Thanks in advance.
Old 11-06-2010 | 02:03 AM
BrianBrave's Avatar
<--- Huge Horsepower
Default Re: Temp sensor and thermostat location????
Welcome aboard - hope this helps you out..
Old 11-06-2010 | 04:55 AM
doesn't get any better than that.....
Old 11-06-2010 | 09:26 AM
Don't forget to lock of the belt tensioner with the pin to keep some slack in the belt or you will have some trouble.
Old 11-06-2010 | 11:59 AM
srt6vic's Avatar
Wow, thanks alot , didn't expect illustrations, this forum is great.
Will post as soon as problem is solved, thanks again.
Old 11-06-2010 | 01:03 PM
MikeR's Avatar
You might want to check and make sure that the radiator fan is working too.... it if stops you will get a low coolant light too.... since you got a CEL it probably isnt the fan, but it wont hurt to be sure it is working properly....
Old 11-06-2010 | 03:02 PM
srt6vic's Avatar
Thanks and what a great looking car you got.
Old 02-08-2021 | 01:19 PM
ebrunning's Avatar
I went to change my temp sensor today and when I took the old unit out the old part practically fell apart in my hands when removing. I got the clip off and rest of the old unit out but can't for the life of me see how to get the clip and wire connector back on without removing the unit above it to gain access. Is there a trick to putting this unit back in?
Old 02-08-2021 | 01:27 PM
I don't even know where the temp sensor is.
I found it, page 7-30 of the 2004 Service Manual. Typically, the sketches are not helpful in finding the sensor's location. Well, not all THAT helpful, I suppose if I was looking at the engine I could figure it out with the manual in hand. The manual claims you can replace it without disturbing other items.
Old 02-08-2021 | 04:06 PM
ebrunning's Avatar
Thanks pizzaguy......I got it figured out. I had to use a needle nose pliers to get the clip in the proper position and then a flat screwdriver to press down on it. Took me 4 attempts to get the clip in the correct orientation.
Old 02-09-2021 | 05:06 AM
philosophico's Avatar
The proper way is to remove the housing that is blocking it at least that was the case for me because if that clip is not secured it will allow the coolant temp sensor to shoot out as it is under pressure and it will leak your coolant out, ask me how I know.
So I hope yours is secured properly.
Old 06-02-2021 | 09:48 AM
Daisyd's Avatar
hello, for some reason the pictures aren’t showing up🥺
Nynick8 (08-04-2021)
rampntlion
21
02-11-2019 08:18 AM
amx1397
10-02-2015 05:20 PM
caseydeankopp
09-13-2015 07:25 PM
bobbie
09-12-2015 12:49 PM
2004_
09-04-2015 01:39 PM
Quick Reply: Temp sensor and thermostat location???
