Give me your opinion please.
Re: Give me your opinion please.
Originally Posted by oledoc2u
well, it could be something else and not the intercooler....just won't know until you go looking....I can tell you this, Kirk wouldn't have let it leave if he would have known it...it got what it needed....that old boat racer is particular about his motors...
dont know if you tracked down the water problem yet but I had the exact problem in a dodge Rader( mitisbushi once. wouldfill the resivor tank up take it for a drive then checke the water when I got home and voila it was 1/2 gone. never a puddle in the driveway or any wetness in the engine bay. It turned out that I had a small pinch in the head gasket and when the vehicle got up to pressue the hot water would shout out as steam and evaporate instantanously. took about 3 months to track that gremlin down. vehilce had only 18k miles on it and it was a factory defect when the head was bolted on and the gasket shifted. at low presser everything worked just fine. had to find a mechanic that could run 60 miles an hour beside the car to spot the problem... hah hah.
collardog
collardog
collardog
collardog
Well it took 9 months but the dealer is replacing the intercooler under the service contract! They found water and coolant stains in the intercooler when it was removed for inspection.
It appears that the best identifiers for an intercooler leak are O2 sensor failure and minor loss of coolent with no external leak. As stated by other members: The standard dealer pressure checks, dye checks and exhaust gas coolant mix test do not prove anything when it comes to an intercooler leak.
Dealership says the replacement intercooler is on back-order. Appearently there is somewhat of a demmand on intercoolers for this engine. The estimate is 1 week to get the car back.
Well 1 week has turned into 3. The dealer now states that the intercooler is approved by Chrysler but is on backorder with no estimate of receipt. Service manager states the part could arrive in a week or months, just can't tell. Between trouble shooting and repair the dealer has had this car for more then 4 months in 2011 and this is after I told them what the trouble was in the beginning.
Originally Posted by dinasrt
I've always questioned "Backorder". If it's sitting on a shelf somewhere, then someone is not doing their job in tracking it down and getting it to you. If it needs to actually be made/manufactured; then I can understand backorder. Can our IC's be repaired properly? Seems like I've read a thread about that. We know radiators can be brazed. I would be beyond diplomacy phase with the dealer. Hope it works out soon for you.
My stealership actually might have one on hand in their parts department. I recently brought my car in for an intercooler pump change (all covered under warranty) and the tech told me that it was both the intercooler and the intercooler pump and it would take a couple of days to get the parts, I was going to tell him that all my symptoms were indicative of just a intercooler pump but I held my tongue (My powertrain is completely covered under warranty and who doesn't like free NEW parts?). In the end though the tech order everything and as far as I know I was told a week later that all my special ordered parts had come in. Brought the car back to get the parts installed and the tech tells me that instead of fixing both the intercooler pump and intercooler he was able to fix the problem by only swapping out just the pump (Should have told him that at the beginning, but what ever). So to make a long story short I believe that there is a intercooler sitting on the shelf of:
Town & Country Jeep Chrysler Dodge | New Chrysler, Dodge, Jeep, Ram dealership in Levittown, NY 11756
I don't know where you live or if this helps you, but you could try and contact them to see if they still have the part and then see if they'd ship it to your stealership, Overall I don't know how Chryslers' parts department work but at least I was able to locate an intercooler for you.
Didn't expect to be loosing water when I started the trip home. Once I realized I was, I didn't have much of a choice but to keep going. I would never have expected a low milage motor (roughly 15k) to pop an IC, but the water is going somewhere. The car is parked now until I can get the extended warrentee transferred and take it to the dealer. Hopefully, they will cover both issues.
No two words together ever sound sweeter.
Originally Posted by 32krazy!
if they dont have it try any mercedes dealer and tell them its for a slk32. same part and they can get them. try skyland automotive in n.c. they are the dealer behind oediscounts.com
