its ugly but getting there... twin-charged SRT-6!!!
  #221 (permalink)
Old 10-29-2010, 01:24 AM
Eric's Avatar
Default Re: its ugly but getting there... twin-charged SRT-6!!!
Originally Posted by rcompart
Impressive numbers and look forward to seeing what you're able to do with 30PSI when you get there! Just a suggestion, I'd grab the tach signal from the cam sensor so you're not getting the spikes in there. That being said, keep up the good work and I hope to see what your little beast will do when you're done.
how's my afr's at around 27# of boost.. i beleave im still running a lil lean .. what you think?
  #222 (permalink)
Old 10-29-2010, 01:27 AM
Eric's Avatar
oh and do you have a pic of the cam sensor where your talking about taping into just so i dont mess it up
  #223 (permalink)
Old 10-29-2010, 07:41 AM
tunaglove's Avatar
How are you not triggering an overboost error??
  #224 (permalink)
Old 10-29-2010, 08:08 AM
yes, very.
  #225 (permalink)
Old 10-29-2010, 10:23 AM
MikeR's Avatar
I believe you can tap the camshaft position sensor at the ECU, connector C3, pin #2.....
  #226 (permalink)
Old 10-29-2010, 11:25 AM
Eric's Avatar
i do if i dont reset the computer and give it time to lern after fixing a boost leak or uping the boost
  #227 (permalink)
Old 10-29-2010, 11:40 AM
Eric's Avatar
i beleave thats the one i have it in.. just want a pic or somthing to make sure.
  #228 (permalink)
Old 10-30-2010, 09:45 AM
rcompart's Avatar
Where are you making your ground connection then? A lot of times the issues with these when you're grabbign a signal from sensors on the engine is the ground differential if you're not using the same ground path as the sensor. Here is a little install guide I made a few months back to help people out. Big thing is getting all your grounds in the same place and pulling your power from the same place the ECU is getting it so your 12VDCs, 5VDCs and grounds are all uniform. If you do have the tach input on the cam sensor wire on C3-P2, maybe redo the rest and see if that helps. If not, you may have a cam sensor that's on it's way out. Good luck and BTW, you need more fuel up top as you should be running 11's with that much boost. I'm curious how much timing your engine was pulling at those AFRs.
  #229 (permalink)
Old 10-30-2010, 11:24 AM
MikeR's Avatar
Rudy, I knew you had that... I just couldn't find it.....
  #230 (permalink)
Old 11-11-2010, 09:47 PM
Eric's Avatar
another 160mph run... uped the fuel to 77 psi.. getting closer i beleave
my 2nt afr gauge is showing a lil lower then what the Z is picking up .. about -1.0 or so .. its befor the 2nt cats.. and the Z one is about 6in after the turbo on the exhaust... It was about 50 degrees out at the time also
looks like a 23sec from 0 to 160 or around there also
  #231 (permalink)
Old 11-12-2010, 01:27 AM
Interesting!
Do you know your Intake Air Temperature at 28PSI? How much Ignition Timing are you running at redline and how much ignition timing is pulled back if you stay longer on the throttle?
Do you have the possibility to measure your Speed (160 MPH) with GPS, e.g. Garmin?
23 sec. for 0-160 MPH is not bad...
Good luck with your Project and stay safe!
  #232 (permalink)
Old 11-12-2010, 06:20 AM
Coyote's Avatar
What I'd like to know is just how far did you travel in those 23 seconds?
How much road did it take to get to 160? And, then, how much more road
did it take to get back down to 0. It would be interesting to compare that
with the brochure stated info of 0 - 100 - 0 mph at around 15 seconds.
Coyote
  #233 (permalink)
Old 09-08-2011, 06:02 PM
Eric's Avatar
Its almost there. Board out to stock size but put steal sleeves in and upgraded the pistons with Ross pistons also lowerd the compression to 8.5 to 1 to be able to run higher boost
  #234 (permalink)
Old 09-08-2011, 08:27 PM
tunaglove's Avatar
Insane in the membrane!!
  #235 (permalink)
Old 09-08-2011, 11:43 PM
ProjectMayhem's Avatar
Awsome living the dream... wish i still had my srt6. I went with 8.0 compression pistons on the 2.4Liter turbo I'm building. was almost talked into getting 8.5 compression but i wanted to be able to run it on 91 octane at 24+psi.
  #236 (permalink)
Old 09-09-2011, 07:28 AM
Eric, that is insane, good luck!!
  #237 (permalink)
Old 09-09-2011, 04:10 PM
Eric's Avatar
just wanting it compleated with no issues b4 the dragon
  #238 (permalink)
Old 09-23-2011, 08:04 AM
Eric's Avatar
all put togather with 185 pully upgrage, Will be in the car today
  #239 (permalink)
Old 09-24-2011, 10:13 AM
Eric's Avatar
back in yesterday with intercooler upgrade
  #240 (permalink)
Old 09-24-2011, 01:14 PM
32krazy!'s Avatar
care to expand on the i/c upgrade?
Quick Reply: its ugly but getting there... twin-charged SRT-6!!!
