Engine flutter? Normal?
Old 05-17-2010 | 03:48 AM
satellite's Avatar
Default Re: Engine flutter? Normal?
Originally Posted by billvp
mine has the same fluttering/wheezing sound that is most prominent at 3/4+ throttle when I'm passing someone ... it sounds like it is coming from the passenger side, and sounds kind of like if a piece of paper was stuck in a bicycle spoke, then when you are going fast, it hits the wheel brace part repeatedly
I can't hear it with the windows up and the radio on, but definitely hear it with the top down. I'm fairly certain it did not make the sound when stock. My car has 20k miles on it.
it doesn't make the sound at idle
I did a search on "bad bearing" noises, and it sounds nothing like the "rocks rattling around" sound.
Bingo...this has to be the same sound I am hearing. I'm still thinking it might be the bearing, but I agree it sounds nothing like other "bad bearing" videos. I posted the videos above to possibly show where the sound is coming from...but...I can't really see the SC making that noise when spinning in one direction consistently.
Old 05-17-2010 | 03:41 PM
mjgroves's Avatar
Yep, I have to agree with you. Paper in bike spokes sounds like another perfect description. We have got to figure out what this is, it drives me nuts.
Old 05-18-2010 | 05:25 AM
satellite's Avatar
Chances are it's just injector noise...lol...apparently it's a common theme for the newbies whining about it. However, I will be looking into it more this week and weekend.
Old 05-22-2010 | 01:57 AM
mjgroves's Avatar
Keep us posted! I would consider this my highest priority, it's bugged me since I got the car. First thing I noticed.
Old 05-22-2010 | 01:58 AM
billvp's Avatar
maybe it's lifter tick?
Old 05-23-2010 | 03:21 AM
satellite's Avatar
I hope not, SRT tech said it might just be CAI noise/surge from not having the baffles that the stock intake had. I will keep looking into things...
Old 05-23-2010 | 11:15 AM
FireAnt's Avatar
Hey guys...After reading through all the decriptions of the noise you're hearing, It kind of sounds to me like a small exhaust leak...especially the fact that it gets louder with increased throttle but not necessarily increased rpm. I've had header leaks on some of my cars in the past that were most noticible if you had the car in a semi lug and rolled the throttle on fairly agressively. As the cylinder pressure increased so did the noise.
Maybe something to look at...Check out your exhaust manifolds?...
Old 05-24-2010 | 02:27 AM
satellite's Avatar
Yes...definitely something to look into. My plan is to get a good recording of it here soon, but yeah that is absolutely another possible reason for the noise...I will check it out, thanks!
Old 05-24-2010 | 02:33 AM
Infinite's Avatar
Well, describe the noise. Does it sound like bb's in a coffee can? sandpaper?
A bearing going bad has a pretty distinct sandy sound.
As far as the flutter, when the clutch on the SC engages, the motor loses power due to the parasitic losses from the energy required to turn the supercharger. You might be feeling that but also the first time the lobes start spinning they have to pressurize all of the air between the supercharger and the intake valves. This sometimes can have a cluttery compressor surge like sound to it, since basically the supercharger is fighting this solid wall of air
Old 05-24-2010 | 03:09 AM
satellite's Avatar
I've almost ruled out bearing going bad. Somebody earlier described the noise as a piece of paper in a bike wheel and I would agree. It's not super loud. I would say it does sound a little like compressor surge (my SRT-4 used to have that on higher boost), but I just didn't think the C3 pulley would be putting out that much boost. I will do my best to get a high quality sound clip of it in the near future.
In the first part of your paragraph the SC engaging, I absolutely recognize/feel that...and this sound is totally separate from that.
Old 05-24-2010 | 03:40 AM
Infinite's Avatar
well, its not about how much boost, theres no bypass valve on srt-6's
its more than likely just harmonics of the air initially being pressurized, or at partial throttle the supercharger is trying to compress more air than its receiving, that too could cause a compressor surge like sound. almost a squeaky wheezy flutter
Old 05-24-2010 | 01:57 PM
mjgroves's Avatar
Well, we know at least 3 or 4 SRT's have this symptom... I cant imagine all of us would have manifold leaks. But, we'll see! I wish I was more savvy about this stuff or I'd be helping... best I can do is grunt and point.
Old 05-24-2010 | 05:09 PM
FireAnt's Avatar
Sometimes the best answer is also the simplest.
Exhaust leaks can manifest themselves as many different hisses, spits, and whistles....and be damned aggravating.
The cardboard in the spokes description seems to be a sound a leak could make. Good Luck!-Rusty
Old 06-01-2010 | 04:24 PM
satellite's Avatar
Got to take the car out yesterday and drive it pretty much the whole day. Did a lot of "spirited" driving...and noticed that as the car warmed up and got driven harder...the sound started going away. Not really went away entirely, just blended in better with the engine noise and exhaust tone...very wierd.
I'm getting a nice sound recording setup here shortely and I WILL record this. I know I'm not going crazy...haha...
Old 06-10-2010 | 05:58 AM
satellite's Avatar
SOUND CLIPS ADDED!!!!!
I'm still getting used to this high quality recorder...so might have you adjust your volume, but you can hear the flutter usually earlier on in the acceleration. Goes away as the exhaust gets louder. Does this help? I'm leaning towards possible exhuast leak.....
Also, isn't the SC whine pretty quiet for mods (NW CAI, C3 pulley, LET tune...etc.)?
Windows Up:
SRT-6 flutter (windows up) - SRT-6 noise when under load, windows up, "flutter", also SC whine seems very quiet for NW CAI and C3 pulley.
Windows Down:
SRT-6 flutter (windows down) - windows down, under 40 mph in 2nd gear
Old 06-10-2010 | 06:12 AM
satellite's Avatar
The reason I am leaning towards exhaust leak (at the headers/manifold) is that my truck just started leaking badly from the headers and it's a fairly similar noise....here is that noise...as you can tell MUCH more prominent....
What are the chances that BOTH of my cars get the same issue at the same time...
be careful...louder clip
99' Dakota R/T Exhaust Leak at driver's side header - Most likely gasket is just completely bad from header bolts working their way out....
Old 06-10-2010 | 01:26 PM
mjgroves's Avatar
Yep, that's the sound I hear. Not only is it annoying, but it makes the car sound like its 30 years old. It's more prevalent at low RPM in a higher gear, but as the engine noise gets louder due to higher RPM, you can't hear it as much.
My transmission fluid is leaking so I need to take the car in for service anyway. I'll tell them about the flutter and see what they come up with.
  #38 (permalink)
Old 06-10-2010 | 02:29 PM
dinasrt's Avatar
If it's an exhaust leak... and I'm not certain how you would do this on the 6, but when my Diesel Truck had a difficult to pinpoint exhaust leak, they did a smoke test. Used the exhaust back pressure sensor bung to inject smoke from smoke machine. I've also used the old rubber hose (3/4"or 1") stethescope to listen for leaks, but difficult in the newer tightly compact engine compartments. Hope you find it. Good luck.
  #39 (permalink)
Old 06-10-2010 | 06:04 PM
satellite's Avatar
Let me know what they find out. I'm almost positive that it's an exhaust leak as the rear cats have been removed on this car and I'm guessing that's what started it.
  #40 (permalink)
Old 06-15-2010 | 12:30 AM
amatxcrossfire's Avatar
well i bought my car about two months ago and heard the problem when I first got the car and thought it was sc, did not think much of it. so like a week ago my alternator went out and let tell you its a tight fit going in and out, but anyway after all back together and start it up and no more noise! and that might be the cause of the surging the other people are having, just my two cents, good look, oh bye the way you can get your alternator check out at almost any parts store, good luck
Quick Reply: Engine flutter? Normal?
