Code3 + 178 or 181 or 185 pulley
Re: Code3 + 178 or 181 or 185 pulley
Originally Posted by tighed1
According to the dyno that just read my roadster at 332HP & 349ft-lbs,
my coupe did 350HP & 464ft-lbs.
DYNO SHEET
The butt dyno said it was faster. Now I know.
DYNO SHEET
Very nice numbers! What dyno were you on and where in the hell did you find that monster pulley???
Originally Posted by SRTpowa
I had one of the first code3 mid-pulley's with the ASP 178. Had a lot of issues with the gator belt slipping. Still managed a 12.0@115 with the pulley slipping and on 19" street tires.
Got a video of it running 12.1@115 just before the 12.0 pass.
YouTube - SRT6 12.1@115 on 19" street tires
My AFR was in the 11's if I recall correctly with the mods in my sig. Car ran strong and surprised quite a few people.
Eric has taken it to a whole new level with the twincharged setup. I just hope he does something to upgrade the fuel system before turning up the boost.
Originally Posted by tri_zombie
Hey tighed1
The guy took a XF Crank pulley, turned it down and attached an outer ring (they make various sizes to adjust boost) from a Ford crank pulley from a supercharged Ford engine (Harley Davidson or Lightning).
Think there may be one other person running a 192.
The 192 came with the car.
Thanks, I’m always continuing on the quest for more power. What set up were you using when the S/C seized ?
