Coolant Leak
Old 01-26-2010 | 10:27 AM
lekrut's Avatar
Default Coolant Leak
Hey all! I have a coolant leak i can't find. I can see coolant on the uder cover of the engine. I have tried to find it but no luck. Anyone else run into this issue?
Thanks,
Lance
Old 01-26-2010 | 10:43 AM
chevyboyac's Avatar
Default Re: Coolant Leak
Have to go the engine hot then checked? if you jack the car up and get the engine hot I would think it would be fairly easy to spot wipe everything down with a rag first, the coolant will leak out alot faster when its hot and theres pressure in the system.
Old 01-26-2010 | 11:26 AM
srt6_crossfire's Avatar
Thanks,
Lance
you might have an intercooler issue. the second time i had the i/c issue, coolant would go low with no signs of a leak.
Old 01-26-2010 | 12:56 PM
lliden's Avatar
Are you sure it's coolant? I thought I had a similar leak, but it turned out to be rainwater from the car being left outside. The rain collected on the bottom engine cover, and eventually dripped onto the ground. I took off the engine cover, and clear water poured on the ground. Keeping the car in the garage at night has eliminated the problem. :-)
Old 01-26-2010 | 01:24 PM
patpur's Avatar
Senior Member/Moderator
I've also seen oil leak from the filter area and puddle down there. Saw it on Jake80's a while back. Turned out the oil filter was loose.
Old 01-26-2010 | 01:30 PM
waldig's Avatar
Talking Re: Coolant Leak
Here we go with the old school thing.
Stick you finger into the fluid.
Touch another finger with that one.
Take the second finger and touch your tongue.
Does it taste sweet?? Thats antifreeze.
Cant find it, get some UV dye and do a search in the evening / dark.
Woody BTW ATF does not taste, new oil same thing.
BTW BTW battery acid is very tart, which is why u touch one hand to the other to reduce dosage.........
Old 01-26-2010 | 01:47 PM
tighed1's Avatar
What side of the engine compartment?
I just found out that my Johnson is leaking!!!
I hate when that happens!
Old 01-26-2010 | 01:48 PM
hcarter's Avatar
ALSO YOU WILL GET THE LOOK
Old 01-26-2010 | 01:51 PM
32krazy!'s Avatar
dj maybe you should see a doctor!!!
a leaky johnson is nothing to play with!
Old 01-26-2010 | 03:02 PM
Depends if it gets serious.
Old 01-26-2010 | 03:05 PM
MikeR's Avatar
Yes..... that could be very embarassing....
Old 01-26-2010 | 03:13 PM
BrianBrave's Avatar
<--- Huge Horsepower
Perhaps you should follow Woody's instructions....????.....
Does it taste sweet?? Thats (Censored...).
Woody ....
Old 01-26-2010 | 03:32 PM
rcompart's Avatar
Between this and the post above it, I don't know what's funnier! LOL
Old 01-26-2010 | 04:09 PM
///SilverSaphRT6's Avatar
This one wins!!!
Old 01-29-2010 | 12:24 AM
cruzinquick's Avatar
Good stuff tighe1 take care of your johnson and get out here before the weather goes away
minimayhem
16
08-23-2016 07:47 AM
debradegiovanni
09-27-2015 09:39 AM
suelo
09-18-2015 05:01 PM
RacerXofFL
09-15-2015 05:00 PM
williammt
09-06-2015 11:23 AM
Quick Reply: Coolant Leak
