Finally took some Pics of car
The pic of the wires showe how you can run the wires out of the BCM Box with out having to drill any holes. Just use needle nose to spread open the existing gromett and slide the wires thru. Well I hope the pics are attached. How do you set up the photo gallery?
Re: Finally took some Pics of car
I like the Toyo's better than the PS-2's I had they seem to have a better ride and less road noise. You have to heat the Toyo's up more as the temp drops since they are a summer tire if you don't heat them up good they will spin like crazy..
Rob I used a hand nut driver to tighten up that way I could not over tighten.
mhajek18
12-30-2015 03:40 PM
