Valvoline G05???
Old 11-13-2009 | 08:15 PM
kolevski's Avatar
Default Valvoline G05???
Well my 2nd time at the track was not as fun as the first.
My upper radiator hose was off the clamp and got sliced by my thermo fan on my first run!!
long story short I was forced to put in what ever water I could find to get the car to a service garage, now its back home and I'm going to need to flush the radiator I read in the book Valvoline G05 is recommend but is a pre mix okay to use? I noticed our stock coolant is blue this stuff is green any help would be awsome
heres the link
935.57 Zerex G-05 Pre-Mix 5L - Lubricants | buy car parts
Old 11-13-2009 | 08:25 PM
bmorgan's Avatar
Default Re: Valvoline G05???
Did you at least turn a good time on the run? Sorry you had problems. I am going to the track in the morning. I will let you know how it goes. Do you have any more track days coming up?
Old 11-13-2009 | 08:28 PM
What track are you going to?
Old 11-13-2009 | 08:30 PM
kolevski's Avatar
hey bmorgan, i took out my cold air intake (doing some modification) so stock cold air intake, 20" wheels, stock pressure and no burnout I managed to get a 13.1 that was my first and only run of the night!
I have one more event on Dec 4th so hopefully I'll see the mid 12's then!!
goodluck for tomorrow make sure you get in the mid 12's
Old 11-13-2009 | 08:39 PM
32krazy!'s Avatar
i have seen were it was said the g-05 can be used in the 3.2 s/c engine. color isnt the issue. the additives and the anticorrosion protection is what you need to look for. for the price it seems about the same as the oem coolant. a key detail is to fully flush the old water out and use a mix with only distilled water. i dont know what the z-05 is mixed with the minerals have been eliminated in distilled water. aluminum heads aluminum block dont use reg tap water
Old 11-13-2009 | 08:47 PM
kolevski's Avatar
I thought if you buy "pre-mix" you dont have to add any water?
Old 11-13-2009 | 09:16 PM
32krazy!'s Avatar
you dont. but you also dont know what type of water they added. its better to buy full strength and add your own distilled water. you also get 2 gal. for 1 gal of non mixed for the same price as 1 gal mixed
Old 11-13-2009 | 09:46 PM
bmorgan's Avatar
Going to Silver Dollar Raceway. I am going with Buggin. He just put a C3 pulley on his SLK320. It should make for a good race as we will both have basically the same setup. He has the C3 intake, and I have the NW CAI. Other than that, we are the same. We will both be on street tires.
Old 11-13-2009 | 10:05 PM
Huh. Not that far away.... I might just come down there.
Thinking.... I sure wont' race, but might learn something.
And the weather should be 100% wonderful!!!!!!!!!
Old 11-13-2009 | 10:19 PM
32krazy!'s Avatar
maybe you might be interested in seeing buggin and bmorgan and myself get our tunes from tony on 12/12. its at dynolab in marietta. maybe you will want one!
Old 11-13-2009 | 10:35 PM
bmorgan's Avatar
Woaaaaa!!!!! Did I miss something? I did not know that we had a date or location set yet. Woooo Hooooo. I am stoked. Any info on deposits yet.
PizzaGuy... come on out. we should start drag racing around noon.
Edit - Ok, I just saw the update about the tune in the other thread.
Old 11-13-2009 | 10:43 PM
LantanaTX's Avatar
There are only three formulations of coolant and the kind you need is the HOAT type. I just filled my new engine with Valvoline G-05 and bought full strength and mixed with distilled water. The advantage of HOAT is anti-corrosion in alluminum engines.
Old 11-13-2009 | 11:42 PM
kolevski's Avatar
Most coolant makers strongly advise using distilled water so I'd be pretty sure that they would mix it with that!!!
the SRT takes 13.5 quarts from my understanding! so would 5.3 quarts of concentrate G05 be enough for my car?
Old 11-14-2009 | 01:02 AM
splinter's Avatar
Sorry to hear of your frustrating go at the ‘strip.
Ashland’s G-05 HOAT formulation is the former DaimlerChrysler’s currently specified anti-freeze.
It’s subtlety repackaged for their dealerships.
Respectfully suggest one purchase the full-strength blend, and only then mix as required with readily available and inexpensive distilled water to achieve a ~50/50 concentration. No sense paying an exorbitant premium for the “convenience” of a petroleum concern diluting it by half beforehand.
Know you’re well into the warm season, but its anti-corrosion properties best not be discounted.
reference
https://www.mbwholesaleparts.com/Sta...iFreeDec04.pdf
File Type: pdf
Old 11-14-2009 | 09:05 AM
kingkub57's Avatar
I believe that BMW offers Blue coolant also, not sure if it will work in our xfires but worth looking into, and even SAAB used the blue coolant as well.
Old 11-14-2009 | 09:32 AM
LantanaTX's Avatar
Color doesn's mean anything. You only need to make sure it is the HOAT formulation. Unless of course you really want to find HOAT in Blue?
Old 11-16-2009 | 08:00 PM
kolevski's Avatar
Thanks Lantana, what is the HOAT formulation though? I cant find G05 anywhere so I might have to buy another brand! what should I look out for on the label?
And before you guys say buy it from Mercedes they quoted me $25 per ltr lol
Old 11-16-2009 | 08:05 PM
32krazy!'s Avatar
thats for full strength coolant mix it with 1 gal of distilled water for 99 cents and you have 2 full gals. of coolant 50/50 mix for 13$ each.
Old 11-16-2009 | 08:10 PM
kolevski's Avatar
Thanks 32krazy, I just found a very simple explanation by Valvoline for anyone else interested
http://journal.mtansw.com.au/08/sept...ntTechTalk.pdf
They use distiled water in there pre mixes so I'm going to buy pre mix! am I correct in saying the SRT-6 takes 13.5 quarts?
Old 11-16-2009 | 09:10 PM
70GT6's Avatar
NAPA carries Zerex G05 about $13 a gal
Also, this might sound strange but that upper hose bracket is a joke. Snaps quite easily and the hose is not held very well.
I found the Mag-Light mounting clamp fits perectly. Has a hole that lines right up to the mount for the origianl clamp and it is at least 10x more solid and actually looks pretty good.
Quick Reply: Valvoline G05???
