Valvoline G05???
Re: Valvoline G05???
Originally Posted by 70GT6
NAPA carries Zerex G05 about $13 a gal
Also, this might sound strange but that upper hose bracket is a joke. Snaps quite easily and the hose is not held very well.
I found the Mag-Light mounting clamp fits perectly. Has a hole that lines right up to the mount for the origianl clamp and it is at least 10x more solid and actually looks pretty good.
WOW! my car doesnt even have a clamp!! guess it broke off before i ever got it. looks like a trip to pro bass tommorrow and gettin me a mag lite clamp!
So I am reviving a fairly old thread here because tonight I just had to top off my coolant. Three weekends ago I changed my IC pump with Johnson CM30. I thought I was good to go but my coolant light came on on Sunday and I noticed one of the hoses leading to the pump had a very slow leak causing me to lose coolant.
Order the Zerex G-05 coolant online (not the 50/50 blend but the full concentrate version) and, after tightening the hose to stop the leak. Added about 1 - 1.3 quarts of the G-05 coolant to bring the coolant level up to about an inch from full to top off the remaining OEM Mercedes blue fluid.
I didn't think to add distilled water to the mix until after. Am I going to damage my engine with the amount of un-distilled G-05 I put in with the Mercedes fluid (which is distilled)? Should I go ahead and add distilled water to top off the remaining 1 inch until full line?
Feeling pretty dumb right about now. Your input is appreciated.
Fla_Xfire_SRT
06-29-2015 06:51 PM
04Fire
16
12-19-2011 07:55 PM
James1549
10-09-2011 09:49 PM
