huge issue
huge issue
Last week I drove home from work and the car just decided to have every gauge light go on turn off my headlights while driving at night and turn itself off???? I left it alone overnight and went back to it and it started right up but drove as though it was running on only 2 of its cylinders...? Its been 3 days and I went to try and start it up again? Well it started right up and so I rolled dwn the window and tried to put it drive and nope???? It wont allow me to move it into drive or reverse? it just stays in park! all my lights keep coming on and worst part is it wont let me roll back up my windo I and I live in WA where it has been raining for th past few days so I went ahead and taped up the window with garbage bags so it wouldnt get into the car but some obvioulsy did, I cant move it into the garage and I cant get it towed what do I do???? Any help would be great? I cant understand what in the world is going on with this car as of late?????
thanks for all the help in advance
Re: huge issue
Re: huge issue
Originally Posted by MikeR
My first thought is your batter is going bad.... if it is low voltage or CURRENT it can make the car electronics act really wierd....
LOTS of weird things happen when the battery starts going bad.
PLEASE report back with status updates so we all benefit.
Thanks!
Rain???? What's that???
Re: huge issue
well, my son's old '97 Grand Am just did the same thing. It is definetly electrical with his. Wasn't the battery, but we were just getting ready to replace a leaky head gasket. So, we are thinking moisture got into the eletronics. We are tearing into his this morning. The neutral trick will work to move the car, we had to do it to his, but it would run in limp mode, so we were able to get into the garage. You might not even need the screw driver, just your finger will usually unlock the shifter. I am with the others, try the obvious first, have your battery checked at the local auto store. We started at the battery and working our way up the electrical chain. The old car has been thru all 3 boys, and has 130K on it...it's been a good car, hate to retire it. Good luck, but you mentioned it had been raining, I would also look into the control boxes if it isn't the battery...moisture and electronics don't work well together
Re: huge issue
took it to a mercedes dealer and did a full scan and it pulled 14 codes....so i'm guessing it has something maybe to do with a short somewhere...? this is going to get expensive and I dont know if im ready to fork over all this money to fix this car.... this sucks and I just got this car running the way I wanted....if the car had a face the front clip looks like its moping right now
Re: huge issue
On the drivers side fender well inside the engine bay is a connection point for multiple computer grounding wires. Make sure the nut that hold the different wires is tight, as that is what caused Bat's Limited Roadster all sorts of electrical gremlins after 2 months of ownership.
On Bat's car, its in front of the shock tower, directly in line with the ABS pump, and there are 3 large gauge wires connected to it. If the nut is loose, the computers that connect to that ground will have an intermittent grounding connection, and will eventually short them out, like what happened to her car. She went through 1 ECM, 3 BCM's, and something in the Airbag system before they found the loose ground point.
BC.
Re: huge issue
Originally Posted by Bladecutter
Another thing to look at.
BC.
BC.
jimf
10-10-2015 10:22 AM
2005 Ragtop
10-03-2015 03:01 PM
