I have a ticking sound in the engine
Old 08-23-2009 | 06:35 PM
H.K. Phooey's Avatar
Default I have a ticking sound in the engine
I had an exhuast leak. I think it caused a valve to go bad. How much an I looking at to fix this? Should I have the heads re-worked or just fix the bad valve? I'm tired of fixing problems but know that comes with the territory of having a fast car.
Old 08-23-2009 | 06:53 PM
Default Re: I have a ticking sound in the engine
Exhaust leak, valve damaged, what is the connection?
Tearing the engine down for a ticking noise is looking for trouble where none probably exists. Bad valve seating can be found with a pressure test on the cylinders. How bad is the tick, mine ticks a little when cold, lifters probably.
Old 08-23-2009 | 06:55 PM
It was a 1.5" crack in my header and that could cause an over heating condition in the valve.
It ticks loudly and sounds bad.
Old 08-23-2009 | 07:13 PM
Illegal Machine's Avatar
Buy aftermarket warranty, wait until it becomes active, pay $100 deductible?
Old 08-23-2009 | 08:17 PM
I only have 26,021 miles on the car.
Old 08-23-2009 | 08:42 PM
velociabstract's Avatar
I've had header leaks before and it never caused a problem with the valves. I can't imagine how the exhaust manifold cracked. If it was excessive heat I think a bad leaky valve caused the manifold to crack and not the other way around. But I'm no expert. Do a compression test and leak down test before anything else. I would do everything possible to not take the motor apart.
Les
Old 08-23-2009 | 10:17 PM
They were custom headers.
Old 08-23-2009 | 11:10 PM
BrianBrave's Avatar
<--- Huge Horsepower
Hey Scott - Are you going to make it to the Texas Mile in October?
I'm planning to enter when I return from travel next month - it would be great to see you again. (and all other XF owners willing to take on the mile.....)
Old 08-24-2009 | 10:45 PM
I have made everyone and will make this one as well. Get your hotel early or try the Holiday Inn next the the Best Western. I still think I will run the same speeds but it's about the people as well as the speed. Hopefully the car is ok.
Old 08-30-2009 | 02:50 PM
I'm about to pull the valve covers and take a look around, my warranty was up in may..dang it.
Old 01-03-2012 | 04:16 PM
sk8erjosh09's Avatar
Sorry to revive this thread but did you ever figure anything out? I have been wondering for a while why mine ticks... Its not brutal and you can only notice it if your listening for it outside the car. One guy the other day said I have a leaky valve. Im going to run a compression check when I can but I stumbled across this and wanted to know if anything ever came from it.
Old 01-04-2012 | 11:19 AM
AlG's Avatar
AlG
I have that same sound. Have it for the whole time I own the car (4+ years). It's probably the injectors. Either way, it doesn't affect the car and it goes away when it warms up.
Old 01-04-2012 | 11:38 AM
ZAHANMA's Avatar
Mercedes is notorious for having very loud lifters...it is normal operations as far as I understand it.
Old 01-05-2012 | 03:23 PM
pjpsrt's Avatar
scott no longer has the car
i do.
the car moved all the way to the next zip code from him to me
the tapping problem was piston -wrist pin clearance w scored cylinder walls
solved by a short block and rebuild of heads
this is per the work order from the chrysler dealer in houston
who supposedly rented a guy from mercedes to do the actual engine work
a page and half of parts w 19 qts of oil tells me the truth may be something else
puking over tightened intake gaskets, misalinged boots on the y pipe and bad seal job on the valve covers tells me the guy probably wasnt a merc mech
however the tapping isnt present so cest le guerre
happy gnu ear
IGot2P
10-24-2023 02:56 AM
rperry52@live.com
02-14-2019 12:18 PM
Ralph289
08-19-2015 08:27 AM
IsaacF
08-13-2015 07:01 PM
Rusty475
07-13-2015 10:03 AM
Quick Reply: I have a ticking sound in the engine
