Do it yourself DIY Belt Wrap Kit for less than $25
Re: Do it yourself DIY Belt Wrap Kit for less than $25
Awesome thank you. We recently went to the 1/4 track and the car was about .5 second slower than normal so I plan to do the minor mods and retune, try and figure out what's going on
I am going to try this on my SRT6 to possibly resolve my boost issue. 12-14 psi on a 65 and that's the max I am seeing on hard pulls. Never been over 14. Normal driving is like 5-8. Question: I actually have the NW PSK bracket, but not the pullies. Could I use the NW PSK bracket with D.J.'s BWK?
Well SRT6 fans, I just completed this mod. It was fairly easy to get it done. Good news are that I don't have anymore belt slip. Bad news is that unfortunately I'm still experiencing the same low boost readings issue. I'm not getting more than 13 psi at WOT and 8-10 psi at normal acceleration respectively. I also replaced the serpentine belt and the big stock smooth pulley underneath the s/c pulley. The new smooth pulley is smaller than the stock one which provide better clearance between the belt. I bought it from Auto Zone, part #89098. In the case of the top idler closer to the s/c pulley, I smoothed it out enough so the grooves don't cause any damage to the belt. See the pictures attached.
In the other hand, today I will take some time to replace the s/c oil. I'm still looking what is causing the low boost on my car. The issue started upon I installed the NeedsWings OilAir Separator. I have verified the whole installation process but there's nothing wrong with it. Last option will be to check the Y pipe for any leak. Let me know guys what you think about it, any help would be appreciated.
Re: Do it yerself DIY Belt Wrap Kit for less than $25
check my album for that modification and by the way i can provide a kit that will do that and i can modify the ribbed pulley to make it smooth( i do it on a lathe) just send me your wheel in a box and return address and check for $60.JAMES FASOLD 149 CENTURY RD DANVILLE PA. 17821
2005 Ragtop
10-03-2015 03:01 PM
