Camber Adjusting Advice!!!
if you lower your SRT6, and do the camber adjusting, here is an important tip: there are two diagonal-lying braces at the front of the car near the front suspension. i could NOT figure out why my car was making SO MUCH noise after i lowered it and set the camber!!! it was horrible, i thought the bushings were bad or something. it would clunk over bumps, and make nasty grinding sounds over any slight level changes at low speeds.
i got her on a lift and lo-and-behold, the metal braces rub slightly against the suspension!!! it was METAL-ON-METAL! so popped them off and took a large hammer and pounded a little more room for the suspension to travel. (it's hollow metal) DONE! no sounds at all!
might want to make this a sticky.
franklindm
03-14-2020 12:23 PM
2005 Ragtop
10-03-2015 03:01 PM
atdavis2
09-21-2015 01:25 PM
