This battery IS a lightweight TaaaDaaa
Re: This battery IS a lightweight TaaaDaaaa
Originally Posted by j-fire
I like these better. can withstand everyday use and temp changes:
http://www.tirerack.com/accessories/...2317FRP8&ID=32
http://www.tirerack.com/accessories/...015CFRP8&ID=30
http://www.odysseybatteries.com/battery/pc680.htm
I had the pc680mjt (metal jacket, car terminals)
Originally Posted by mrphotoman
I have used this one in the past, 15lbs and survived 2 winters here and the battery is still going strong on its 3rd year for the new owner:
I had it on a V6 and it worked great.
Originally Posted by RL-2005
ok now we are talking, but how do you think your old car and this car compared interms of electrical starting load? what cca did your old car's stock battery call for? just trying to do the research as i may pickup a lightweight battery soon. i got my pc680 for less than $100 but alot of them seeem to be $150 plus now. even though ive heard many are the exact same battery with different stickers on them. hawker, westco, deka, odyssey, braille, etc.
i do not recall the specs on it, the 680 is 680cca.
Both batteries look good, just throwing out another option.
You can get the Braille batteries in as light as 6.6lbs...............there's a guy on M-B forum running it in his CLK63 AMG(with 6.3L v8 under hood).
I have a Deka ETX14, supposed to be the same battery that Braille sells. It weighs just under 12lbs. It has died a couple times when I let the car sit for over 2 weeks, but now I have a trickle charger if I happen to not drive it for a while. I had to move my IC tank and CM30 pump to the trunk to make room for my new purple box.
Yeah those are nice but really expensive. Aren't they like $300?
Originally Posted by jturkel
is it an easy retrofit? as easy as taking out the older battery and putting in the new one, and ensuring it stays in place?
Good battery and If I decide to replace the one in the crossfire I will probably get another.
No the cable can go underneath. That is where I will add mine. the box is already in the sandbox-garage waiting for next weekend.
I'll connect the power cable to the alternator lug, which is where the started is connected to get the power down from the battery.
This is where the lite battery April fools day joke came from. I wanted to buzz the kno knotts at the drive in scene. Hope you all enjoyed the fun, it was interesting to put together.
Woody ENJOY and Partee
