Another VIDEO (Chris's Meth Kit Install)
Old 03-19-2009 | 10:57 PM
cross><hair's Avatar
Default Another VIDEO (Chris's Meth Kit Install)
Another vid for you guys. This one was a mix of shots from my standard Canon XH-A1 and the 5D mkII DSLR. Enjoy...
http://www.gmelliottvideo.com/srt6meth.mov
Old 03-19-2009 | 11:39 PM
XF-LV's Avatar
Default Re: Another VIDEO (Chris's Meth Kit Install)
The suspense is killing me! Were is part 2??? Please
Grant
Old 03-20-2009 | 12:19 AM
Eric's Avatar
very awesome.... wish there was a lil more instruction though but thats just cus iv got a meth kit i want to install hehe
Old 03-20-2009 | 12:31 AM
MMZ_TimeLord's Avatar
Yep, I'm itching for part 2 as well... excellent work on both the Crossfire SRT6 AND the video cut!
Old 03-20-2009 | 05:29 AM
Bigkid's Avatar
Just like an end of season cliff hanger on the tube. Again great video, waiting for part 2. Thanks for sharing.
Old 03-20-2009 | 08:44 AM
Bulldogger's Avatar
Running both pulley's you're still going to need bigger injectors.
Old 03-20-2009 | 09:16 AM
distantpulse's Avatar
You may be right, but I am going to test it out. After talking with Rob, James from InMotion has done the same thing im trying to do with success and I believe he did not change anything in the fuel system other than the tuning. My meth is not working right now (wiring issue), but when I do get it working, I expect it to get richer.....How much? I'm not sure, but it will get richer. My hope is that it gets about a 1.5 to 2 richer that way when I add the SC pulley, we will be up in the area of where we could dial it in. Again, this is all a test at this point so.......
Old 03-20-2009 | 09:34 AM
BLKFIN's Avatar
ADDICTED TO BOOST
Great videos! If we all were so technical this would be a better forum! Keep them coming~
Old 03-20-2009 | 09:41 AM
Bulldogger's Avatar
I hope it works for you, but I was under the impression that Dave Rockwell who posted "this is how I got power" on the forum was already running the meth kit and was still lean.
Old 03-20-2009 | 10:25 AM
Remember that the SRT6 injectors are quite large to begin with. They may be able to get the richer run by tuning alone. The injectors should be good up to about 400 HP without 100% duty cycling at red line if I remember right.
Anyone else remember what thread that was where someone figured out the maximum duty cycle on both the base/Limited and SRT6 injectors?
Old 03-20-2009 | 11:34 AM
Bulldogger's Avatar
They can't my set-up and at 5300 rpm's I'm out of fuel and that was with Wayne from LETdyno tuning in person. Chris is running a 178 and Code3 combo more boost probably 4 lbs. Chris will let us know.
Old 03-20-2009 | 03:59 PM
SRT6-Man's Avatar
Looks good guys! Get those Stang wheels of that Crossfire.......LOL.....
Old 03-20-2009 | 08:29 PM
Not trying to insult Wayne, but I'd like to know was he altering the fuel map specifically, or did he just flash a different car's 'bin' onto your ECU?
I only ask, because unless someone actually has the ability to alter the fuel map and pulse width then it's just a shot in the dark hack to me.
Dyno tuning in the loosest terms. They re-flash your ECU until they get the highest numbers they can on the dyno. Here's the rub... if they just use stock or pre-made ECU bin files, then it's just finding the best of the lot, not actually 'Tuning' anything.
This has been my biggest issue with 'tuning' over the years. I've seen people drop big dollars for what is, for all intents and purposes, a simple reflash. They ended up paying through the nose for someone to go through a bunch and find the best one and not really ever 'tune' the car.
[/rant]
Again, I'm not trying to insult those that dyno tune cars, I realize it is work and the software to really get into these ECUs is REALLY expensive. But I hate the terminology that's... well, just not accurate.
Old 03-20-2009 | 08:52 PM
Bulldogger's Avatar
I'm pretty sure they are adjusting pulse width and duration, they have the calibration charts up on the screen and make adjustments through the rpm range, that is why they needed to stop at a certain duty cycle.
Old 03-20-2009 | 10:04 PM
MD SRT6's Avatar
I have made multiple 10 sec. 1/4 mile passes( see dragtimes.com for one of them,plus there was atleast ten members there watching), never went lean on stock injectors/pump. I won't argue what hp it takes to do this as some here dispute the numbers, but about 550hp @ the flywheel based on the cars weight with me in it (from my research/previous dyno's). So why is everybody running so lean??? My Inmotion tune with a small piggy back kept me within 11.8-12.7 or so.....I was running N2O, but having said that, it still requires extra fuel to support it. Based on that I think the injectors and pump are more that capable of handling what you guys are throwing at it. It must be the tuning ?!? My other thought is you may be running lean on the dyno and not at the track, dyno's are a pretty weird environment for a car, I think everyone should try there cars out on the track before completely trusting the dyno numbers. Get a wideband and go to the track!
Old 03-20-2009 | 11:03 PM
jonnyangel04's Avatar
I was watching that video and saw this pillar looking thing with gauges hahah where might someone pick something like that up lol?
Looks beautiful, Can't stand the to be continued lol not cool at all
Old 03-20-2009 | 11:13 PM
XXxx_Totmacher_xxXX's Avatar
What Jets wear you running, specifically the fuel jet. Just curious, not doubting.
Old 03-20-2009 | 11:34 PM
Illegal Machine's Avatar
http://www.srtforums.com/forums/f18/...esults-448952/
Check out this thread, Tach. You think the "red SRT-4 with full parachute" was anyone you know? haha
Old 03-21-2009 | 11:08 AM
MD SRT6's Avatar
NX pro fogger with 62-n2o & 35-fuel, which = 150 shot.
Old 03-21-2009 | 12:16 PM
lol, I thought I'd put a little ode to your handy work in there. I need to order a set but want them painted to match the stock a-pillar color. Is that possible?
Quick Reply: Another VIDEO (Chris's Meth Kit Install)
