Another VIDEO (Chris's Meth Kit Install)
  #61 (permalink)
Old 04-01-2009 | 10:13 AM
cross><hair's Avatar
Default Re: Another VIDEO (Chris's Meth Kit Install)
Originally Posted by distantpulse
Ok, that is what I was thinking, but wasn't sure. Now that makes more sense.
Chris...man- *sigh* I feel for you man. I guess it's time to order the teflon-coated y-pipe from rob and run the boost line from the passenger side mani.
  #62 (permalink)
Old 04-01-2009 | 10:30 AM
distantpulse's Avatar
Good minds think alike although I am not a happy camper right now.
  #63 (permalink)
Old 04-01-2009 | 10:44 AM
cruzinquick's Avatar
Grrrr!! Ok, so that makes sense to me, but where do you tap in at? I can't tap into the rubber elbow?
Yes that would be a good spot. A fellow I race with has a tacoma sc and he tapped farther down the CAI just after the filter. You'll get it worked out soon, and to think great weather for you is just starting.
  #64 (permalink)
Old 04-01-2009 | 10:45 AM
mrphotoman's Avatar
i never got to run it after i increased the boost to 11psi, i ran a 13.2@105 with 8psi. it was a super reliable car even with all the mods on it.
Nice I'm a previous of not one but TWO previous Tiburons-
PS What times were you pulling with that SC'd Tib?
  #65 (permalink)
Old 04-01-2009 | 10:53 AM
waldig's Avatar
Talking Re: Another VIDEO (Chris's Meth Kit Install)
Oh Boy Oh boy
If I say somethumkin Iam going to geta woopin.
What the heil, I strongly suggest and recommend injection be on the pressurized side of the intercooloer. It is the only place from a thermodynamics perspective. Really.
Adding the spray before the s/c will do many things that you do not want!!!
First cooling the charge is the most serious: As the material evaporates and changes state the inlet air is cooled. This is BAD cause it lowers the air temp entering the intercooler which reduces its efficiency, the IC is trying to gain heat taking it from the air. Cooler air is harder to cool than hotter air.
The material added also will retain some of the heat of compression and add to the density of the air lowering its temp. Again harder to cool. ALSO the material sprayed in dilutes the oxygen charge entering the engine especially as it expands upon evaporating, bad bad....
The SC will have to pump the material adding to its work load, remember were dealing with 10,000 plus rpm here.
If the pressurized spray is added to the wye for instance, it further cools the charge entering the intake manifolds which is GOOD. The charge is pressurized and adding fuel / water now will not reduce the O2 content much.
The spray could be done at the manifolds as long as it is balanced WELL and is not favoring one cyclinder or side over that of another.
I have run water injection before and will possibly do it again, and offer these thoughts for your benefit and consideration.
Be Well, WOODY
  #66 (permalink)
Old 04-01-2009 | 11:03 AM
Originally Posted by waldig
Oh Boy Oh boy
Be Well, WOODY
Ok my brain hurts Woody, so what you are saying is that I DO have it in the right spot?!? What about my high IAT's? Even if it is cooling, the computer still will pull timing with high IAT's correct? So now we have to fool it into thinking it's taking in cool air??
  #67 (permalink)
Old 04-01-2009 | 11:12 AM
mrphotoman's Avatar
The biggest alky injection company says it is safe:
http://www.alcohol-injection.com/for...-6-a-1586.html
bikecop tapped the manifolds and it had the same effect as your Y tap, basically just increased the a/f ratio.
also, are you spraying alky/water all over your air temp sensor in the Y?
  #68 (permalink)
Old 04-01-2009 | 11:15 AM
waldig's Avatar
Help mymemory, what do you have for a HE, that water is important to keep it cool.
While racing for about 60 seconds in first at 6000, my engine shut down on high heat and it was ugly, killing my crank key -pully etc.
This is why I became a cooling dude. Now Iam, free of that and I ran stacked until I started hitting like 25 psi at the manifolds.
WW
  #69 (permalink)
Old 04-01-2009 | 11:21 AM
I would assume since it is tapped in the Y that there would be spray there. ??
  #70 (permalink)
Old 04-01-2009 | 11:24 AM
WW
I have the LET H/E. LOL man you guys aren't making this an easy decision on what I should do! :P
  #71 (permalink)
Old 04-01-2009 | 11:28 AM
waldig's Avatar
Gotta stay away from the sensor, thermal shock and all of that plus water could affect the sensor readings making it seem different than real.
2 nozzels on the pipes would be a good start I believe.
For that Id use the manifolds at the inlet, you can get to them, change them easily, yadda yadda. Putting in a threaded mount there would be reasonable. THe wye is so under there and the sensor is big time important, so Id not wanna get into that area but maybe once in any case.
WW
  #72 (permalink)
Old 04-01-2009 | 11:34 AM
Why did you get rid of it?
PS How much was the SC kit for it? Supporting mods?
  #73 (permalink)
Old 04-01-2009 | 11:44 AM
mrphotoman's Avatar
I just decided to try something new, I was going to get another corvette but found my srt6 and liked it so I bought that.
Roots supercharger kit: $1900 new
supercharger pulley: $100
Crank pulley: $105 (custom made even!)
fuel tuner: $300
CAI: $160
Those were the main mods, i have a laundry list of them though. Here is some pics of it: https://www.crossfireforum.org/forum...hlight=tiburon
Of course the new genesis coupe is 1000x better though.
  #74 (permalink)
Old 04-01-2009 | 04:48 PM
fuel tuner: $300
CAI: $160
Awesome- Opticon is a ****.
  #75 (permalink)
Old 04-17-2009 | 08:56 AM
Opticon's Avatar
xfireohio
07-20-2020 12:03 AM
gp1200x
12-06-2015 12:59 PM
MAXIMUM
08-04-2015 11:04 PM
maxcichon
07-31-2015 06:35 PM
07-29-2015 06:13 PM
Quick Reply: Another VIDEO (Chris's Meth Kit Install)
