Supercooler / heat exchanger
Old 02-25-2009, 08:52 AM
Default Re: Supercooler / heat exchanger
Coming from 6 years of running a Nuclear Machinery room on a Air Craft Carrier I can attest to the strength of three things... Zip-Ties, Duct Tape and JB Weld....
Old 02-25-2009, 09:40 AM
MikeR's Avatar
holy crap.... you didnt have to put that picture in our heads....
Old 02-25-2009, 02:09 PM
BrianBrave's Avatar
<--- Huge Horsepower
Heat and sunlight will distroy zip-ties in short order.
Old 02-25-2009, 02:17 PM
waldig's Avatar
Talking Re: Supercooler / heat exchanger
Not the uv resistant compesistion ones. The ones I use are about 1/3 " wide and 0.080 or so thick.
Old 02-27-2009, 09:14 AM
NeedsWings's Avatar
new p/s cooling line kit, included with h/e
Old 02-27-2009, 09:23 AM
BlUEMDsrt6's Avatar
Hey Rob, will you be coming out with a coolant seperation kit also to go with this super cooler?
Old 02-27-2009, 09:30 AM
NeedsWings's Avatar
yes, it can be done with 2 shutoff valves, very easy/cheap. no need for an extra overflow the way we are running it. one of my valves tends to leak a few drops a night so i need to source out a better one before shipping off those kits.
Old 02-27-2009, 09:40 AM
tom2112's Avatar
She can ride with me ;)
This is probably a dumb question, but how would you check the coolant level without a separate overflow?
Old 02-27-2009, 09:45 AM
NeedsWings's Avatar
open valves, let ic and rad intermix, drive to flush all bubbles, close valves
Old 02-27-2009, 09:51 AM
tom2112's Avatar
You're a genius Rob!
Old 02-27-2009, 10:04 AM
tighed1's Avatar
Just need to cut and plug a couple of existing hoses to do the separation.
Old 02-27-2009, 10:10 AM
tighed1's Avatar
J-fire,
Did you get your cooler installed?
Old 02-27-2009, 10:11 AM
waldig's Avatar
That is what I did only plugging hoses is an ugly business, never find the correct size plug and there are no caps that I feel safe with for capping the outlets. Like the goezouta fitting on the i/c aluminum lines by the radiator tank.
The water in the supercooler has never gotten hot enough to puke out for me and thats at 5 -6000 rpm for up to a minute in autocrossing in all seasons 35 to 90 degrees.
Week end again but windy and no R/C flying for me again....AAaargue.........Woody
Old 02-27-2009, 10:12 AM
Do these zip ties go through the radiator?
Old 02-27-2009, 10:14 AM
j-fire's Avatar
Originally Posted by tighed1
J-fire,
yes, but it's still on the rack getting the Torque converter put in as well as my koni's and H&R springs.
and my 'inmotion' tuned ECU just arrived this morning
tom2112's Avatar
Nope, they go through brackets on the side of the radiator.
Old 02-27-2009, 10:21 AM
tighed1's Avatar
Yes plugging hoses is ugly! Not pretty but very functional.
I will be flying RC this weekend...Really Cool in my SRT!
  #38 (permalink)
Old 02-27-2009, 12:19 PM
Did I miss the pricing on this, or if there's an initial group buy?
  #39 (permalink)
Old 02-28-2009, 11:11 AM
BrianBrave's Avatar
What happens with this closed system if/when the coolant gets hot and needs to expands/surge? Say on a long run, or a hot day or should the IC pump fail?
IMO you'll to design in a pressure relief valve. Same idea as a radiator cap or a water heater.
Without a surge tank for the coolant to expand into (or release pressure)........ You run a high risk of your intercooler bursting since it's nearest to the heat source and the weakest link and ingesting coolant into the engine.
My Dos Centavos
  #40 (permalink)
Old 02-28-2009, 11:12 AM
NeedsWings's Avatar
i guess you missed the radiator cap on the heat exchanger
Quick Reply: Supercooler / heat exchanger
