What has been replaced on your XF under warranty?
Old 02-05-2009 | 08:42 PM
RMADERMAN's Avatar
Default What has been replaced on your XF under warranty?
I bet I win this category.
1. Supercharger
2. waterpump
3. IC pump
4. Roadster top
5. belt
6. radio
7. battery
8. Alternator
9. SRT wing
10. Engine cover
11. seat cover passenger once -driver side twice (heater malfuction)
12. Motor mounts
13. Headlights
14. lifters (maybe)
15. Forgot TSB's
...a. Tranmission seal
...b. Fan
16. Manifold gaskets
17. Foglights
That's all I can think of off the top of my head.
Old 02-05-2009 | 08:45 PM
Default Re: What has been replaced on your XF under warranty?
1. Supercharger
2. waterpump
3. IC pump
4. Roadster top
5. belt
6. radio
7. battery
8. Alternator
9. SRT wing
10. Engine cover
12. Motor mounts
13. Headlights
14. lifters (maybe)
15. now just replace the driver and that car should run great
LOL<<<again LOL
Old 02-05-2009 | 09:01 PM
Mr. Max's Avatar
1. Supercharger
2. waterpump
3. IC pump
4. Roadster top
5. belt
6. radio
7. battery
8. Alternator
9. SRT wing
10. Engine cover
12. Motor mounts
13. Headlights
14. lifters (maybe)
15.
Damn! is that what I have to look forward to. So far mine is light pods, transmission sensor, and 1 catalytic converter (on order). I think if WWII was going on today the ***** would be using Japanese Vehicles.
Old 02-05-2009 | 09:12 PM
spotsbimmer's Avatar
Nothing has had to bee replaced under warranty.
I win going in the other direction
Old 02-05-2009 | 09:47 PM
ProjectMayhem's Avatar
Your car has some serious gremlins mine has only had a bad alternator at 10k. How many miles are you at?
Old 02-05-2009 | 11:39 PM
Wedge's Avatar
Air temp sensor and IC pump
But more in the future
Old 02-06-2009 | 12:00 AM
Mimi05SRT6's Avatar
Wow, doubt if anyone will beat you. I only had the transmission seal and A/C fan relay replaced. I only have 11k miles on her though.
Old 02-06-2009 | 01:27 AM
yellowcard21's Avatar
I have had:
1. IC Pump
2. Temp. Sensor
3. Driver's Seat Heater
4. Both Fog Lights
5. Hatch Bump Stops
6. Driver and Passenger Side Door Panels
7. Passenger Side Trim Piece on Roof
8. Driver's Side Door Weather Stripping
9. Driver's Side Windo Seals
and I'm bringing it in next weak for a leak... woohoo warranty!
28k miles
Old 02-06-2009 | 06:46 AM
kingkub57's Avatar
I have had,
1. cooling fan recall
2. pcm cooling fan
3. seat heater grid repaired [ drivers ] and other seat heater problems its been in 5 times for problems and is there now
4. radio
5. center or middle dash vent
6. rear hatch rattles and stop bumpers
7. noisey cabin fan
8. cabin fan control module
9. corroded cabin fan terminals
10. 4 wheel alignment
11. peeling chrome on driver pull handle [inside]
12. ash tray sticking, wont open, wont stay closed at times
13. cup holder
14. mirror switch they broke when in the console
15. transmission fluid leak
16. loose strakes on drivers fender
17. wiper blades
18. rattle coming from right rear of car
19. wiper arm nut covers
20. fog lights replaced for caps falling out
21. defroster circle vent on drivers side blew out
so far that is all I can think of just on my 05 SRT6, and we don't even want to go into what they did on my 04 coupe.
thank you warranty
05 SRT 6 15k
04 coupe 16k
Old 02-06-2009 | 08:04 AM
Punkin's Avatar
That list, was that for one of your stable or yours and the daughters?
1. Fog lights
2. Drivers seat heater
3. Painted a small area on the roof
4. temp sensor (unneeded)
5. ECU (unneeded)
6. IC pump (needed, and I told them so)
7. Small tranny leak (not sure what was replaced)
That was the SRT. My wifes NA has been prett good. Most work was rear lid adjustment, passenger window adjustment. No parts that I remember.
Old 02-06-2009 | 09:24 AM
RPM's Avatar
RPM
Moderator
IC pump . . that's it so far.
Old 02-06-2009 | 09:25 AM
crossfirefun's Avatar
one headlight replaced and one radio replaced. Glad mine seems to be running fine. I will be scared once I run out of warranty.
Old 02-06-2009 | 12:00 PM
Deevcj's Avatar
IC pump, fuse holder for Supercharger fuse. Glad I bought an extended war.
Old 02-06-2009 | 03:21 PM
ws6vert's Avatar
Drivesr seat heater....now has 10k miles owned since 2/06.....purchased with 200 miles..problem free.....cant understand why some have had so many problems.........
Old 02-06-2009 | 03:30 PM
Oil and filter, five times.
Rear tire, once.
All under my extended warranty gold plan.
What have you guys (edit sorry) gals been doing?
RMADERMAN's Avatar
34,500, so my warraty is almost up.
Old 02-06-2009 | 03:32 PM
RMADERMAN's Avatar
Just mine. I added a couple of things.
Old 02-06-2009 | 07:52 PM
smokey847's Avatar
Why'd you get the SRT wing replaced?
Old 02-06-2009 | 08:46 PM
+fireamx's Avatar
I believe it was due to a rust problem where it mounts to the trunk or hatch.
Old 02-06-2009 | 09:28 PM
smokey847's Avatar
Ah. Alright.
1. Front lower left grille
2. Passenger window strip
3. Rattlin hatch
4. Driver door pull
5. Driver floormat clip
Small list.
Quick Reply: What has been replaced on your XF under warranty?
