BIGGEE Rear sway bar
Re: BIGGEE Rear sway bar
So it’s still pushing a ton during your beloved autocross, eh? Would have sworn I’d seen this thread before. ;=)
Increasing its rear roll couple will indeed help it to rotate. Not sure of your current setup, but there’s no sense in adjusting the front stick less when, in fact, the aft end is not contributing its fair share to the traction equation.
Knowing your fabrication skills and tenacity, forming a larger anti-roll bar should be duck soup during the off season. Failing that, H&R’s R170 ('03 SLK) rear 20mm bar is readily available. I’ve installed their bars and springs with favorable results. They’re quality pieces.
http://hrsprings.com/scripts/appguide.php?Mode=Application+Guide&SubMode=Find2& Year=2003&ModelID=340&q=2003%20|%20Mercedes-Benz%20|%20SLK
Here it is for $179
http://www.erzperformance.com/product_p/71769-352.htm
Let me know how you like it, if it makes a nice difference I will get one as well
H&R is a german company, i have used their springs before and they were great.
Tire rack sells it too:
http://www.tirerack.com/suspension/S...kage&brand=all
Ya know I was warned about stiffening up my Mustang GT's suspension for autocrosses. Some vets told me that in the real-world, like on road curves and road tracks, stiffer suspension is better, but on a tight autocross you want a loose susension that allows the car to lean on its tires and get the front end turned better. These were real vet' guys so I gave what they said some credit and only did partial upgrades.
And coincedently I did my rear sway first as my only suspension mod. I immediately noticed on my next autocross that the rear-end was stiff but the nose leaned like usual, and it caused my car to 'plow' through corners instead of turn.
According to the vet's nothing helps autocross like soft R compound tires and that a stiffer suspension would hurt things.
In fact there were a few people that discovered this the hard way and removed their upgaded suspensions and actually re-bought stock bars and control arms because they had already sold theirs off when they upgraded.
Anyways Woody I know you're a vet' too I just wanted to share my experience. ... The crossfire is a completely different beast so everything I said may not apply.
Originally Posted by tighed1
http://www.p-s-t.com/pc-1283-175-chr...e-2004-06.aspx
Yo Dudes.
Not sure what the stock dimensions are on our SRT's but I use the PST sway bars on my Chevelles and those sway bars are HUGE!!!
Yo Dudes.
Yo Woody,
Did you ever check out the PST I mentioned the last time you posted this question?
Anybody have the stock bar sizes handy???
Could one of you gentlemen kindly contribute to another of Woody’s insatiable quests by measuring your rear anti-roll bar?
Recall that the bar’s stiffness is influenced to the 4th power by its diameter.
Formula:
http://www.tech-session.com/kb/index.php?article=21
Calculator:
http://buildafastercar.com/tech/Sway...ate-Calculator
Superfluous chassis tuning reference guide that may be of interest to some:
http://www.westpennmazdaclub.com/fil...ng%20Guide.pdf
YMMV.
Formula:
Calculator:
YMMV.
Those PST looks promising!
1 1/8 front and 1 rear, didnt mention if they were hollow or not.
Whats the difference between the three I wonder, Polygraphite?
http://www.p-s-t.com/pc-4063-299-chr...e-2004-06.aspx
Well let me be the first, PST has never sold one of the rears and Ill be the first to get both if the catalog is correct. Ill let you know what issues there are in getting them and installing them. Thanks for all the assistance so far, To be continued as they say............
W dy, enjoy the weekend....
NEVER sold one?
Did they tell ya that Woody?
You might be starting a whole new string of sales for them if they work out.
You should of told them that you would evaluate their sway bar and report on it for free! Nothing wrong with free!
Oh, I want my cut too for suggesting them as a supplier!
Actually I did suggest that I could do a product evaluation for a consideration. No soap/joy/ love/luck/ whatever.
Bad thing is that he said that they would call the Factory to get more info for Monday. He let slip the name addco.
I had called and spoke to one of the family a number of years back and was not impressed. I also had BACK in the day run their sway bars on my wigged out 2 liter pinto ( above 7000 RPM was inspirational ) with a 4 barrel carb, 4:11, roll cage, as I started to get into autocrossing. They were primitive I thought, but that is 30 years ago.
Woody
Woody
Originally Posted by waldig
...I also had BACK in the day run their sway bars on my wigged out 2 liter pinto ( above 7000 RPM was inspirational ) with a 4 barrel carb, 4:11, roll cage, as I started to get into autocrossing....
Had a ’73 Runabout as my first car. Racer Walsh engine hardware, Sig Erson cam, 4210 Holley, Quickor suspension, and lots of other ‘essential’ goodies. Ran a 17.45 @ 77 at OCIR. What a turd! Beat up on the Vegas and 510s in HS though.
^ not mine
Thought I’d have grown out of the hotrodding game by now. Apparently not.
Originally Posted by splinter
A Pinto you say? You’re dating yourself, Woody.
