Who has datalogged their srt6? Share info here
If you have the ability to datalog via a PC based OBD2 tool please post up your screenshots here.
Short term and long term fuel trims w/ RPMS
Timing advance w/ RPMS
Boost pressure w/ RPMS
MAP pressure w/ RPMS
I think this would be a very nice way for everyone to compare their cars/tunes to check for issues, abnormalities etc.
I will post mine up tonight.
When you post up, be sure to list your modifications and what type of fuel you are using (octane).
Re: Who has datalogged their srt6? Share info here
Here is mine. This was just past the 1/4 at 116mph with the 178, NW intake and LET Tune running 93 octane.....
Frame 16 Time 91.8
1/4 mile(116 mph)
MIL STATUS OFF
ABSLT TPS % 99.6
ENG SPEED RPM 5953
CALC LOAD % 100.0
MAF FLOW GR/SE343.00
MAP KPA 234
COOLANT F 192
IAT F 163
IGN ADVANCE DE -7.6
SECOND AIR ATMOS
ST FTRM1 % 0.0
LT FTRM1 % 0.8
ST FTRM2 % 0.0
LT FTRM2 % -1.0
VEH SPEED MPH 116
FUEL SYS 1 OPEN1
FUEL SYS 2 OPEN1
O2S11 V 0.030
ST FTRM11 % 0.0
O2S12 V 0.005
O2S21 V 0.880
ST FTRM21 % 0.0
O2S22 V 0.940
OBD2 STAT CA
Frame 16 Time 91.8
1/4 mile(116 mph)
MIL STATUS OFF
ABSLT TPS % 99.6
ENG SPEED RPM 5953
CALC LOAD % 100.0
MAP KPA 234
COOLANT F 192
IAT F 163
IGN ADVANCE DE -7.6
SECOND AIR ATMOS
ST FTRM1 % 0.0
LT FTRM1 % 0.8
ST FTRM2 % 0.0
LT FTRM2 % -1.0
VEH SPEED MPH 116
FUEL SYS 1 OPEN1
FUEL SYS 2 OPEN1
O2S11 V 0.030
ST FTRM11 % 0.0
O2S12 V 0.005
O2S21 V 0.880
ST FTRM21 % 0.0
O2S22 V 0.940
OBD2 STAT CA
Frame 16 Time 91.8
1/4 mile(116 mph)
MIL STATUS OFF
ABSLT TPS % 99.6
ENG SPEED RPM 5953
CALC LOAD % 100.0
MAP KPA 234
COOLANT F 192
IAT F 163
IGN ADVANCE DE -7.6
SECOND AIR ATMOS
ST FTRM1 % 0.0
LT FTRM1 % 0.8
ST FTRM2 % 0.0
LT FTRM2 % -1.0
VEH SPEED MPH 116
FUEL SYS 1 OPEN1
FUEL SYS 2 OPEN1
O2S11 V 0.030
ST FTRM11 % 0.0
O2S12 V 0.005
O2S21 V 0.880
ST FTRM21 % 0.0
O2S22 V 0.940
OBD2 STAT CA
Frame 16 Time 91.8
1/4 mile(116 mph)
MIL STATUS OFF
ABSLT TPS % 99.6
ENG SPEED RPM 5953
CALC LOAD % 100.0
MAP KPA 234
COOLANT F 192
IAT F 163
IGN ADVANCE DE -7.6
SECOND AIR ATMOS
ST FTRM1 % 0.0
LT FTRM1 % 0.8
ST FTRM2 % 0.0
LT FTRM2 % -1.0
VEH SPEED MPH 116
FUEL SYS 1 OPEN1
FUEL SYS 2 OPEN1
O2S11 V 0.030
ST FTRM11 % 0.0
O2S12 V 0.005
O2S21 V 0.880
ST FTRM21 % 0.0
O2S22 V 0.940
OBD2 STAT CA
Thanks
Originally Posted by waldig
WHAT DATA LOGGER IS BEST TO PURCHASE FOR THE sRT, I am considering purchasing one for playing. Thanks W DY
Elmscan 5 USB with ScanXL software
http://www.scantool.net/products/pro...6abeacab611bd5
Info on the software:
http://www.palmerperformance.com/pro...lelm/index.php
Jerry recommended this one to me. It seems to do a good enough job although it's nothing fancy.
http://www.actron.com/product_detail.php?pid=16318
Huh; I never thought of using my scan tool to data log.........silly me. I have an Actron CP9175 that I bought just to scan and clear codes on the 6 and have been datalogging with just my Zeitronix gauge setup(boost,AFR,LAMBDA,EGT). I'll have to see if my scanner will log as well.
This is the one that I have: http://www.auterraweb.com/dyforwiusb.html
You can find it cheaper in other places tho.
I datalogged a few items, let me know if you spot anything odd. My psi still shows low but I am making the same power as the other code3 guys. That one has my puzzled.
The way this forum is set up you will need to scroll to see all of the charts.
LE Cross
10-17-2016 06:35 AM
wannaGOFAST
South Forum
08-14-2015 01:20 AM
