Has anyone had there 185mm Pulley Fail?
Old 09-15-2008, 12:09 PM
Montana Crossfire's Avatar
Default Has anyone had there 185mm Pulley Fail?
We all know there were some 181mm pulley failures but does anyone know of or has anyone HAD a water pump pulley fail on a 185mm setup?
I lost my entire pulley this weekend at highway cruise speed just desided to go to pieces. I need to know who if anyone has had problems with theirs. This is only for the 185mm failures so smaller pulley owners need not chime in at this time. Nothing like a $460.00 tow charge to put a damper on a weekend.
Mike
Old 09-15-2008, 12:22 PM
BlUEMDsrt6's Avatar
Default Re: Has anyone had there 185mm Pulley Fail?
Have not had a problem. Is yours a daily driver?
OUCH, sorry to hear about that towing bill.
Old 09-15-2008, 12:55 PM
SRT6 Gang Member's Avatar
THREE 6S
I lost my entire pulley this weekend at highway speed just deside to go to pieces. I need to know who if anyone has had problems with theirs. This is only for the 185mm failures so smaller pulley owners need not chime in at this time. Nothing like a $460.00 tow charge to put a damper on a weekend.
Mike
Mike,
Can you clarify which pulley failed, crank pulley or wp pulley?
Subscribed.....
Old 09-15-2008, 01:01 PM
240M3SRT's Avatar
Originally Posted by SRT6 Gang Member
Mike,
Subscribed.....
Thats the same thing i was wondering.
Let me give you all a friendly word of advice. Periodically check the 6 hex cap bolts on the crank pulley to make sure they are tight.
Old 09-15-2008, 01:47 PM
hawksview's Avatar
i dont want to put words in his mouth but from his statement it looks like the water pump pulley failed to me
Old 09-16-2008, 02:56 AM
waldig's Avatar
This is why I went to the code 3, all the accessories are not over sped. Less stress, but then I really go at it for up to 60 seconds at a time in a run. Woody
The factory pulley is steel, think they have experience in this area.
Old 09-16-2008, 05:33 AM
Bulldogger's Avatar
I don't think any crank pully's failed it was the water pump pulley. It doesn't matter if it was the 178/181/185 pulley, the recall was for the water pump pulley that came with them and that's what the recall addressed.
Old 09-16-2008, 05:59 AM
waldig's Avatar
Not so fast, My 181 sheared the crank key and flew off, killing the water pump, perferated the oil pan, and bent the crank...........so it can happen. Sorry,Woody
Old 09-16-2008, 06:09 AM
Bulldogger's Avatar
I thought you had the water pump pulley go at the same time so you were unsure which happened first, also didn't you take the crank pulley apart before the problem?? not implying any thing just don't remember anyone having crank pulley problems. I do know that when I got mine the center hub was not tight with the allen keys and could have caused a serious problem if I didn't check it first before install.
Old 09-16-2008, 06:15 AM
I have 185 wheel
My water-wheel crash yesterday, only 30hr driving.
The 4 bolt was realy tight.
Have mail Let but dont get any answer.....
Lasse / Sweden
Old 09-16-2008, 06:30 AM
Bulldogger's Avatar
Star,
did the updated water pulley break? or the old style thinner one?
Old 09-16-2008, 06:48 AM
240M3SRT's Avatar
When you guys see the updated water pump pulley you will never worry about it failing again.
The most important thing about the 185-181 crank pulley is check those hex bolts and use red loc-tite! If you hear something that sounds like rod knock and then see your pulley wobbling rest assured the bolts have lossened and sheared off.
Waldig is the only person i know who sheared the keway off the crank. I dont understand how this could have happened. I have installed/uninstalled my 185 pulley about 15 times now, no issues yet with the keyway. As far as the keyway slot in the 185 its the same as the stock one...just a cut out grove.
Old 09-16-2008, 07:32 AM
waldig's Avatar
While running I got BAS/ESP codes due to overheating and the power loss ( sudden nose dive) caused it to snap back and forth enough to do it in. Not something I wanna deal with again. THere is too many failures going on and someone will get into a real pickle if they are in traffic at the wrong time.
Woody
Old 09-16-2008, 10:52 AM
Originally Posted by Bulldogger
Star,
Dont think i have the new upgrade wheel.
The information i get is, -No problem if you have 185-wheel.
That was realy wrong look att the picture.
Old 09-16-2008, 12:12 PM
240M3SRT's Avatar
Woody
I respect the heck out of your inginuity and what not, but its hard for me to grasp your train of though on this one.
I believe BAS/ESP has to do with the brakes. Overheating also seems unrelated to an oversized crank pulley. If the car nose diving under deceleration is going to destroy a crank pulley by causing it to snap back and forth then it wasnt on tight in the first place.
IIRC, didnt you have to modify your crank pulley to get it to sit flush on the crank? Wondering if this has anything to do with the fact that your the only one with the keyway problem. Im not blaming, simply wondering.
I do agree there are more problems then what should be going on, but the causes are being remedied as they appear. Its got the gears in my head turning(Waldig close).
Old 09-16-2008, 01:14 PM
NEED TO CLARRIFY...
It was the Water Pump Pulley. When I said 185 pulley failure I just assumed since it was the Water pump pulley so often discussed on the forum that everyone would know what I ment. But now that you have mentioned the hex bolts on the main crank pulley I have something else to worry about.
Mike
Old 09-16-2008, 01:41 PM
THREE 6S
NEED TO CARRIFY...
Mike
Thanks for the clarification and it sucks your worry became reality.
Good luck.
Old 09-16-2008, 02:02 PM
RMADERMAN's Avatar
Attachment 11444
This picture is what my 181 water pump pulley looked like. Unfortunately, I had not seen the recall notice till it was tooooooooooooo late. Jerry had Eric overnight the corrected/new pulley to me. There response was immediate.
Old 09-16-2008, 02:42 PM
cruzinquick's Avatar
That 178mm ASP pulley setup is looking like a pretty safe choice right about now. With Renntech and ASP the only companies that put out pulleys for the MB version of our motor, there is still unknown issues to the motor that the larger pulleys may cause. I know it's been discussed over and over, but if it was safe and proven those companies would of produced them.
Old 09-16-2008, 03:27 PM
mrphotoman's Avatar
wow i sure am glad i went with the cheaper and safer code3 pulley.
i hope your car did not get damaged too bad.
Quick Reply: Has anyone had there 185mm Pulley Fail?
