BrianB... your brackets are done
on
Brian & Voyager,
Here is a pic of your SL55 brackets. I will wrap them up and get them out to you via USPS. Please PM me your addresses as I cant seem to find them. I know they're hiding in my computer somewhere!
These should set the air boxes just about at the factory points for hight. The front ones came out so good for alignment I may have to make me a new set. I tapped all the holes to 10-24 to make it easy. The front ones just slide right into one side of the existing bracket after you pull the clip off. You will have to do your own drilling. Just snap the clip onto the new bracket. It should be pretty snug and WONT come off easily. Have fun.
Mike R
Mike R
<--- Huge Horsepower
Re: BrianB... your brackets are done
Thanks Mike - those look trick!! So much better then the off-the-shelf flat stock brackets I used.
Now you are in line for reduced price on the next mod I’m designing. I hope it comes out as nice as the mock up..
PM Sent....
PM Sent....
Mike - I got the brackets in the mail today and installed them. Very nice work. I must say they look very trick, clean and professional. Much better then the flat stock I used before.
I also think they provided me with a solution for mounting the engine cover once I get around to extending it and making it fit snug like the stock set up...
Here are some pics. The first picture is how it was.
Let me say again -- Thank-You
https://www.crossfireforum.org/galle...y.php?cat=1102
on
2005 Ragtop
10-03-2015 03:01 PM
MAXIMUM
08-04-2015 11:04 PM
ohnoesaz
07-24-2009 01:56 PM
